Old 10-24-2011, 10:55 PM   #1
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Dually wheel adapters
I am looking to see if anyone knows how thick of an adapter I need to convert my SRW 3/4 ton to DRW on the rear.?? I am using a dually bed also.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 10-24-2011, 11:54 PM   #2
BigBlocksRule
Re: Dually wheel adapters
Well, there's 4 1/2" difference between the two (67.5" vs 72"), I'd guess a 2" adapter would work fine, you'll never notice the 1/4" per side difference.
BigBlocksRule is offline   Reply With Quote
Old 10-25-2011, 03:31 AM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
www.arrowcaraft.com
'nuff said
EXCELSIOR!!!
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 10-25-2011, 12:07 PM   #4
rs72z
rs72z's Avatar
Originally Posted by BLE 'BURBAN View Post
Man they are proud of those.
rs72z is offline   Reply With Quote
Old 10-25-2011, 12:33 PM   #5
BigBlocksRule
Try ebay, there are a few different sellers with all thicknesses.
Off topic - does anyone know where I can get wide dually wheels? I need some 16x10's for my project.
Old 10-25-2011, 01:39 PM   #6
rs72z
rs72z's Avatar
Anybody run the aluminum spacers? Do they hold up ok?
Old 10-25-2011, 03:25 PM   #7
texassquarebodies
Truck Nut
The aluminum one are alot cheaper than the steel ones. Arrowcraft wants $415 for the rear ones.
Anyone have the aluminum versions????
Tony Kee
Texas Square Bodies
Old 10-31-2011, 08:57 AM   #8
Desert1957
Desert1957's Avatar
I'm not sure I would trust the aluminum style over the billet steel setup. This is the one place you do not want to have a parts failure. If the discount style breaks or comes apart , both wheels come off.
The eBay cheap one look like a great deal, but too much risk for me.
Desert
Desert1957 is offline   Reply With Quote
Old 10-31-2011, 01:02 PM   #9
jonessmc87
jonessmc87's Avatar
http://wheeladapter.com/ there is no place better for wheel adapters. These things are awesome quality, (i have a set myself) and they have awesome service. Fred, will most likely personally call you to confirm your order and ask any questions to make sure he machines them to your correct specs.
1989 V3500 nv4500/np205 255-85-16 BFG Mud Terrains, 4inch skyjacker kit, 2 inch body lift.
"Yea, it was a fuel supply problem. A rod came through the block and cut the fuel line."
jonessmc87 is offline   Reply With Quote
Old 10-31-2011, 08:22 PM   #10
BigBlocksRule
Go to a drag race site and see whose they use. I'd do a search at DRR:
http://drr.infopop.cc/eve/ubb.x?a=fr...075&f=80760912
Old 11-02-2011, 10:21 AM   #11
Desert1957
Desert1957's Avatar
Not quite sure what this pictures is showing, ALL Dually conversion I have done the adapter mounts on the Rear end hub FIRST , then both wheels go one.
This lower pictures is showing the Dually adapter being used as a spacer between the rims? WTF?
Desert
Old 11-02-2011, 11:03 AM   #12
78 Chevyrado
You'd put the spacer between the rims to fit wider tires on there so they don't touch.
78 Chevyrado is offline   Reply With Quote
Old 11-02-2011, 11:20 AM   #13
jitteryguy
GoatLube Experss
jitteryguy's Avatar
you could put that spacer on the inside to move bothy wheel's out to where you want, But I would look into a Dually rear end befor I went with spacer's.
what are your plan's for the truck ? hual'n, low'rd or 4X4.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 11-02-2011, 11:52 AM   #14
Desert1957
Desert1957's Avatar
Yes I realize that , but this thread had a link to ( www.arrowcraft.com) which is a company that converts single rear wheel trucks 3/4 and 1 ton to Duallys, their spacers allow dually wheels to be used on the shorter rear end housing, which means the spacers go on BEFORE the wheels.
Desert
