Old 12-01-2011, 01:46 PM   #1
67gmcstepside
Trans and TC reinstall
Thought I would ask those who have done this before. I had to remove the trans due to 3rd gear syncro being shot. I am ready for the re-install and thought it would be easiest to reinstall the trans with the adapter on it and after getting the cross member mounter add the TC. Seems like to much weight if I try to get the trans lined up with the throw out bearing and clutch assembly with the TC on. Does this logic make sense? Doesnt look like to much trouble getting to the adapter/TC bolts once the adaprt is on the cross member. Any thoughts?
67gmcstepside is offline   Reply With Quote
Old 12-01-2011, 07:19 PM   #2
argonaut
argonaut's Avatar
Re: Trans and TC reinstall
That plan sounds reasonable to me if you are doing it from underneath. That way you can put the trans on the jack, mount it all up, then put the transfer case on the jack and get it mounted up. otherwise like you said its a lot of weight and it is off balance from side to side due to the transfer case.
When we did a transmission and transfer case swap on my Dad's 69 we unbolted the bed and cab and slid them back on the frame. Then hoisted one whole assembly out and the other in. it went pretty quickly that way.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 12-01-2011, 09:34 PM   #3
67gmcstepside
yes, it was so much easier when the cab was off, just drop them in. Thank you for the reply!
Old 12-02-2011, 01:53 AM   #4
rcbildr
rcbildr's Avatar
Would it be easier to use an engine hoist with the boom in the cab and lift everyting thru the removable center floor piece? I'm thinking about doing that when I convert my 83 to a manual trans.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 12-02-2011, 09:51 AM   #5
Yukon Jack
Yukon Jack's Avatar
I've done the install both ways and I think using an engine hoist with the boom through the cab made it a bit easier.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-02-2011, 09:53 PM   #6
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Anyone drill out the rivets in the crossmember braces so that you can bolt the two upper pieces in, then raise the tcase and tranny bolted to the main piece straight up? I think it would be alot easier since you have to angle the crossmember in since the upper pieces need to go in the channel.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 12-04-2011, 08:49 PM   #7
67gmcstepside
Got the trans installed and as always learned a few tricks. The first is to strap the trans to the trans jack. I used a rachet strap. Once it got close I laid on my back held the frame rails and used the balls of my feet to get to sink in. Then I tried to reinstall the clutch fork. Found out that you can't install it once the trans is in so out and back in it went. Doing it solo was tough and I am glad that's over. Now all I have to do is figure out why I can't get the shift back in. The trans was completely rebuild by a local shop.
