View Poll Results: Please decribe your airbag setup
I have standard 3/8" Line 16 28.07%
I have standard 1/2" Line 8 14.04%
I have hardlines between my components (cha-ching!) 5 8.77%
I have the PVC/DOT Approved stuff between my components 16 28.07%
Nothing yet...doing my research 19 33.33%
Multiple Choice Poll. Voters: 57. You may not vote on this poll
Old 02-17-2012, 05:38 PM   #1
502ms
502ms's Avatar
Baggers: What do you use to....
Guys,
Simple question. I am curious as to what you used to run the air from your compressors, tanks, bags and gauges?
Also, tell us if you are driving often, if it is a truck that has basic lowering, do you lay frame, and why you made the choices that you did.
Thanks. This might help those of us who are looking to bag our trucks, as well as give us ideas if we have already set it up, and want to find options to reinforce the system.
Thanks!
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 02-17-2012, 10:26 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Baggers: What do you use to....
Money ususally dictates most of our choices.
Spend the bucks on DOT approved air line and fittings.
Use a good sealant on the threads (like Loctite 545)
Keep the air lines away from pinch points, sharp edges and heat.
Buy the best air management components you can afford.
Keith
Convert to disc brakes.
Old 02-17-2012, 10:46 PM   #3
502ms
502ms's Avatar
Great guidance, Lolife
Best Regards,
Leon M.
Old 02-18-2012, 03:46 AM   #4
andrewmp6
Air line size depends on how fast you want it to lift and lower same thing with the valves size too.
Old 02-18-2012, 01:38 PM   #5
blitz'd
vintage car junkie
blitz'd's Avatar
3/8 DOT, anywhere it could possibly rub metal gets sheathed in a larger hose to protect it.
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 02-19-2012, 10:40 AM   #6
502ms
502ms's Avatar
Great idea. Do you use Kevlar to protect from heat?
Best Regards,
Leon M.
Old 02-19-2012, 12:34 PM   #7
texastrendz
I used 3/8 hydraulic hose on my 72, and use a lot of 3/8 aluminum hard line with push lock fittings. The hydrauilic hose is expensive, but will not have failure issues. It is not as pretty as the aluminum, but you do not have to bend it. I like trying diffrent things at diffrent times.
texastrendz is offline   Reply With Quote
Old 02-19-2012, 01:00 PM   #8
68steppsidee
when i goes back under the frame on your truck texastrendz does it change to hard line...
68steppsidee is offline   Reply With Quote
Old 02-19-2012, 01:04 PM   #9
texastrendz
there is no hard line on this truck as far as the air system, it is all hydraulic hose, using nitrogen as an air source.
Old 02-21-2012, 07:50 AM   #10
68steppsidee
oh ok how expensive is that hydaulic hose and can you run just air in it..
Old 02-22-2012, 06:52 PM   #11
made2drag
made2drag's Avatar
hey 68steppsidee,
here is a link although may be more expensive than other places. they usually come premade like the site shows. there may be a place local to your city that may make them. there is a parker store where i live that can make them any length and also a tool company local to me. there may be similar places near you. the psi is rate super high like 3500 psi. yes, you can run air in them. they are overkill but they wont ever fail on you. let me know if you need any more help with questions on bagging.
http://www.northerntool.com/shop/too...3953_200383953
made2drag is offline   Reply With Quote
Old 02-23-2012, 02:25 AM   #12
weekendracer728
weekendracer728's Avatar
Most napa's can make hyd line.
Live life one weld at a time.
'04.5 Chev Duramax CCLB- Winter DD
'03 Grand Prix GT- Summer DD
'67 C10-307/T5(For Now)-R.I.P-Burned Up!
'68 C10-5.3/4L80E
www.one-guys-garage.com
weekendracer728 is offline   Reply With Quote
Old 02-23-2012, 09:57 AM   #13
502ms
502ms's Avatar
Great info! I wonder if it makes sense to re-do my truck's 3/8" line with hydraulic lines for safety
Best Regards,
Leon M.
Old 02-23-2012, 03:47 PM   #14
made2drag
made2drag's Avatar
Originally Posted by made2drag View Post
hey 68steppsidee,
i saw some hydrolic premade hose with 1/4 or 3/8 or 1/2 fittings at Tractor Supply Co. prices were between $11-38 for 2ft-14ft for the 1/2 sizes. i did notice that the center opening of the 1/2 was about the same as a 3/8 dot line. its not real high in price when you consider the connectors you'll have to buy for dot stuff. the hydrolic line would be harder to route.
Old 06-24-2012, 07:26 PM   #15
502ms
502ms's Avatar
I am considering removing the 3/8" DOT air lines I have and going with hydraulic lines. Oh, joy. But, I'm sure I will be happier in the end.
Best Regards,
Leon M.
Old 06-24-2012, 09:45 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
Thats way overkill unless you plan to run super high line pressure.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-25-2012, 12:10 AM   #17
texastrendz
I would run with what you got, I use the hydraulic hose because I have nice access to it and get it dirt cheap. Just make damn sure you cut it square at the ends and route it nicely. Common sense is the key to it. For some folks sense ain't to common. lol
Old 06-27-2012, 03:18 PM   #18
tubbedII
needs more $$$
tubbedII's Avatar
I used 1/2" lines and valves, but only because I had it. It's actually way too fast even with the port from my tank being only 3/8" (doesn't actually hop, but feels like it). If I did it all over, it'd be 3/8" all the way (and accuair), plus the 3/8" DOT line is MUCH easier to route.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 06-27-2012, 03:45 PM   #19
dznucks
dznucks's Avatar
Consider using aluminum hard lines and bending them yourself. Its really not that difficult.
I ran 1/2" hardlines on the supply side of my system (ie, comp to tanks to valve block), then I ran 3/8" plastic lines from the valve block to each bag. For heat and chaffing protection I used Thermo-Tec Heat sheild tubing to route the plasting line through in critical locations.
dznucks is offline   Reply With Quote
Old 06-27-2012, 04:55 PM   #20
Rochlow
I've used stainless steel braid line and -8 A.N. fittings in the past and had really good luck with it. I plan on using it on the truck I'm building now.
Rochlow is offline   Reply With Quote
Old 06-27-2012, 10:01 PM   #21
502ms
502ms's Avatar
Thanks for the feedback guys! I have 3/8 DOT lines. I will probably run that shielding you mentioned above, and call it a day. I don't want it too fast..I like how it works now...
Best Regards,
Leon M.
bags, lines, suspension
