Old 09-11-2003, 09:32 AM   #1
Tito1019
Tito1019's Avatar
Thumbs up 4 Inch or 6 Inch?
I can't decide if I want 4 or 6 inch lift on my 72 jimmy Any advice?
72 GMC JIMMY
67 GTO Post
99 Audi A6 (Wifes car)
Tito1019 is offline   Reply With Quote
Old 09-11-2003, 10:26 AM   #2
3wbdriver
3wbdriver's Avatar
If you plan to run anything taller than a 35" tire, I'd go with the 6". I bought mine with a 4" installed, and 36/14.5's, and the previous owner had cut the front corner out of all 4 fenders to get clearance. I have 35/12.5's on it now, and I'm still concerned about clearance, with any suspension flex, after I restore the fenders to stock.
'72 Blazer, 4WD, 350/4 spd. Affectionately known as "Da Beast"
'04 Silverado (new daily driver)
'00 Intrepid (wife's ride)
It's a BLAZER dude! No options, no emblems, no a/c, no fancy shmancy. It's a BLAZER....
3wbdriver is offline   Reply With Quote
Old 09-11-2003, 10:54 AM   #3
1970blazin
Blazerless:-(
1970blazin's Avatar
I am partial to the 4" I think that a 6" is just a little to much. But it is your choice, and depends on what you are going for. If you want big tires go with the 6". I think it will look good either way..you almost can't make these things look bad!
1970blazin
1970 CST Blazer-Orig. Dark Blue-SOLD
Progress Pics of Blazer for sale
1970blazin is offline   Reply With Quote
Old 09-11-2003, 11:36 AM   #4
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I say 9 inch with 38x15.50's !!!
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 09-11-2003, 11:47 AM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I depends on the tires. My first blazer had a 4" with 35's. The '69 I have now has a 6" with 35's. If your going to wheel it at all, with 35's you should probably run a 6". 4" should give you enough clearance for 33's. Keep in mind, if you run wider tires (like 35x14.5's) you may need more lift. I'd be leary of running anything over 36's if your still running the stock 1/2 gear - you'll be more prone to breaks, especially if you wheel it - (although I'd love to have 9" of lift and 38's!). It can be done though! There is actually a Jimmy in my neighborhood with 39.5's on 6" of lift. He says the suspension is so stiff, the tires are the only thing that absorb the bumps.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-11-2003, 11:59 AM   #6
smokekiki
Mike
smokekiki's Avatar
I have a 4" with 35's,but it is not for off-road use.Any flexing and the tires grab the fender.I have a tuff country ez-ride lift,front and rear springs.It rides pretty good.Better than when stock.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 09-11-2003, 01:34 PM   #7
HatGuy
HatGuy's Avatar
Question
I could go for the "ez-ride" part maybe then I could
get my wife to ride in my 72'
Joe Peters the HatGuy
72' K5 Highlander
My Daily Driver
http://www.pbhats.com/BLAZER/index.html
HatGuy is offline   Reply With Quote
Old 09-11-2003, 01:43 PM   #8
MJN
MJN's Avatar
My Blazer currently has a four inch and 35's on it and I like it a lot. My dad has a six inch on his pickup and I also have a six on my pickup, only to clear the tires though. We went with the four icnh on the blazer so it would be so tall to get in and with the short wheel base it isn't as top heavy as when it had the ten inch on it. So it's basically up to you and what you think is the best looking and the most functional for you.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 09-11-2003, 02:10 PM   #9
smokekiki
Mike
smokekiki's Avatar
The blazer is my Wife's.
Old 09-11-2003, 07:31 PM   #10
71Blazer
Goodbye Darlin'
71Blazer's Avatar
I like these two... 6" lift w/ 35" tires?
1971 Blazer CST SOLD!
71Blazer is offline   Reply With Quote
Old 09-11-2003, 07:46 PM   #11
bouncytruck
SKINNY TIRES RULE!
The bottom one might be 8" of lift, but I can't tell exactly. Here is mine with 6" on 35's.
bouncytruck 1972 K5
Old 09-13-2003, 01:24 AM   #12
Tito1019
Tito1019's Avatar
Wow, thanks for the advice and pictures guys, I think seeing those is what sold me...im going with the six inch running 35s
I'll send out pics when i'm done, thanks again
72 GMC JIMMY
67 GTO Post
