Old 05-03-2012, 10:34 AM   #26
Scottshotrods
Re: Manual rack (MS II type), who is using these?
The rack you want to use is a 88 t-bird power rack
Scottshotrods is offline   Reply With Quote
Old 05-03-2012, 11:38 AM   #27
Handfull 54
Handfull 54's Avatar
To Scotts Hot Rods, why is that the one to use over the 79-93 Mustang. Is it 16" center to center? I have a Fatman crossmember and I used V8 springs with one coil cut out. Now after 500 miles the bottom A frames are 2" above the rack. What springs should I use and should I get some 2" drop spindles also? I am not far from your shop and have talked to you before about other things. Perhaps you can give me some suggestions. Thanks
Handfull 54 is offline   Reply With Quote
Old 05-03-2012, 11:51 AM   #28
Scottshotrods
The power racks we have been useing for several years have been and will always be based on a 88 t-bird
1.Designed and will work with a gm pump no problem at all
2.Not as sensitive as the mustang power racks out there
3.Deisgned to work with a heavier car or truck
4.Now at this time the power racks we have are BRAND new not reman racks.
These just came available to us a little over two months.The best thing on these new racks they come with LIFETIME warrantty so you buy once and never again.
The price on these to buy are $389.00 and come with rack bushings and these have a lifetime warrantty to.You cannot go wrong at all.
5.The power racks at all the parts stores are not brand new at all.They are based off the mustang which had over 17 different power racks you can get at parts stores.
6.The mounting points on our power racks we use are 15 1/2 spread and they even come with the power rack fittings.This means no more messing up the threads at all.
7.The last thing if you are in Moorpark you are more than welcome to come on by and you can take a look at these power racks we have here in stock and you will be shocked on how they look compared to the others on the market.
Justin
Old 05-03-2012, 07:44 PM   #29
paintman
Justin
Justin, How about posting a pick for this stupid guy out in NJ ( you know what I mean) of the new racks you have
paintman is offline   Reply With Quote
Old 05-04-2012, 01:34 AM   #30
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I have been wondering about the T-bird rack and was contemplating upgrading my 40 up to one since mine is leaking and junk.
Ryan
1969 Chevy milk truck
