Old 03-29-2012, 12:19 PM   #1
vjjack04
vjjack04's Avatar
Manual rack (MS II type), who is using these?
Folks,
I now have a power rack, but don't have the truck on the road yet and was considering going to a manual one....anyone using a manual one (who thinks that is the way to go)?
vjjack04 is offline   Reply With Quote
Old 03-29-2012, 12:37 PM   #2
jimig1
jimig1's Avatar
Re: Manual rack (MS II type), who is using these?
I don't have mine on the road yet either but I put in a power rack so I can use a smaller steering wheel.
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 03-29-2012, 12:44 PM   #3
jackson
Originally Posted by vjjack04 View Post
Folks,
if you run skinny tires up front i think the manual would be fine
jackson is offline   Reply With Quote
Old 03-30-2012, 09:49 AM   #4
vjjack04
vjjack04's Avatar
I was just thinking that the manual, because it is designed to be that way - and is is a rack and pinion system, would be kinda cool.
Old 03-30-2012, 04:33 PM   #5
solidaxel
solidaxel's Avatar
I think you will be much happier with a power rack and pinion !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-30-2012, 04:46 PM   #6
vjjack04
vjjack04's Avatar
Just don't want it to be too free...but I have the power rack so I may keep it.
Old 03-30-2012, 09:24 PM   #7
parkwood
parkwood's Avatar
I say what solidaxel says.... you'll wish you had done it...
parkwood is offline   Reply With Quote
Old 03-31-2012, 01:10 AM   #8
55Cameo
55Cameo's Avatar
I have a manual rack i got with my mustang II kit. I will be putting it in within the next couple months and will let you know how it goes. I bought it for a clean simple install so no hoses clutter the engine comp and it was cheaper lol.
I'll be running 15's up front with a 225 or 235
55Cameo is offline   Reply With Quote
Old 03-31-2012, 03:09 PM   #9
vjjack04
vjjack04's Avatar
ok, see, that is what I was thinking.....it would look clean in there with use an alternator...I would think that the racks that are built to have no power, would be easier to use and have a good road feel. But I do not want to half to wrestle it.
Old 03-31-2012, 03:14 PM   #10
vjjack04
vjjack04's Avatar
by the way, I see you are in Tucson. - have you used Wild West Customs for anything? I have and they are a good bunch of guys - in case you need some good TIG welding or something.
Old 03-31-2012, 11:12 PM   #11
solidaxel
solidaxel's Avatar
Check that power rack that came with the front end, and tell me how many turns you have from lock to lock.
There is plenty of room for a pump, and you can get high pressure hose and fittings at Don.s,, take the rack and Jay will set you up for the fittings and route the hoses in a clean manner, go for it you will like to drive your truck
LS 3 4L70E
Old 03-31-2012, 11:23 PM   #12
vjjack04
vjjack04's Avatar
Thanks,
I will likely keep it, but wil put the pump and hoses together myself...who is jay?
Old 04-01-2012, 07:54 AM   #13
solidaxel
solidaxel's Avatar
Thanks,
Jay works at Don's Hot Rod shop in Tucson on Stone Ave.
They have the fittings that will fit the rack and PS pump, If you do not have anything for your plumbing.
When you are placing the high pressure line on the rack be sure to ID the high pressure inlet on the rack, you do NOT want to get them backwards
LS 3 4L70E
Old 04-01-2012, 06:27 PM   #14
vjjack04
vjjack04's Avatar
thanks - i appreciate the info.
Old 04-04-2012, 03:26 AM   #15
55Cameo
55Cameo's Avatar
I've heard manual racks aren't that hard to turn when made for manual steering and feel good, but nothing beats power steering in parking lots lol!!
I'm the same way just looking for clan clutter free install
Old 04-04-2012, 03:29 AM   #16
55Cameo
55Cameo's Avatar
I have never used them at all. I do alot of my work myself and my brother helps me at times cause he has a small shop. I've seen there shop, greats products and work. They said they could help me install my front end and gave me a great price i may take them up on
Old 04-04-2012, 06:55 PM   #17
vjjack04
vjjack04's Avatar
I had them weld in the IFS. They charge a flat rate of about $55 an hour and it didn't take that long. They are a good outfit.
Old 04-04-2012, 07:44 PM   #18
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Most of the street rod guys I know have MII fronts wih manual racks. They swear by them. They say the ratio in the rack is different than in a power ack. My friend's dad has a 40 Chevy with a blown 540 and it has a manual rack. It turns with ease at a stand still. So I may go manual with my 40 ford this time around.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-04-2012, 07:55 PM   #19
Scottshotrods
I would keep your power rack in your truck you will be much happier with it.When you make those right and left turns you will be glad you kept it in your truck.
Justin
Scottshotrods is offline   Reply With Quote
Old 04-04-2012, 09:01 PM   #20
jackson
i had a manual rack in my 63 ford truck. it turned real easy. i wouldnt be afraid of them
Old 04-04-2012, 09:15 PM   #21
IndyBowtie
IndyBowtie's Avatar
Just put a 283 and MII with manual rack in my '48 in Dec. Don't mind it at all. But I also have the original steering wheel. I can see where power would be good with a smaller wheel
IndyBowtie is offline   Reply With Quote
Old 04-04-2012, 11:59 PM   #22
55Cameo
55Cameo's Avatar
When I visited the shop he told me the same thing. I looked at his projects and he was kind enough to take me in the back for a tour. Loved the work. Will def keep them in mind
Old 04-05-2012, 12:00 AM   #23
55Cameo
55Cameo's Avatar
Justin
I still wanna build a truck with power steering as well cause there are those times it makes all the diff in the world
Old 04-05-2012, 12:02 AM   #24
55Cameo
55Cameo's Avatar
Dieselwrencher: I have heard some info like that and interested to see how mine turns out.
Indy Bowtie: You have a valid point there too
Old 05-03-2012, 09:53 AM   #25
Handfull 54
Handfull 54's Avatar
I have power steering on my 54 with a big block. My steering is very sensative. I have been told to switch to a 79-93 mustang R&P because it is less sensative. Other than that I love the power steering. If you use a 79-93 rack be advised it is 15 1/2" center to center. If you have an older crossmember you will need to use off set bushings. The new racks have a slot in them so they can use either the 74-78 or the 79-93. NAPA part # is 22-203-F for the newer rack. This is the one that has 2 3/4 turns lock to lock. Hope this helps.
Handfull 54 is offline   Reply With Quote
