#76 |
Junk Yartist
Re: project pacific wonder
Looking good! Lovin the 4BT!!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#77 | |
![]() Join Date: Oct 2010
so the blue circles are the lights on the roof the red wire drops in throught the roof holes i used the wireconnectors you can pull apart. then routed them all together. the kit from LMC was dissapointing and came with the splice fittings that slice and clamp into the wire. then the power wire runs down the inside of the A post and to the switch it is supposed to be grounded with the mounting screws to the body but i am using that grounding kit and want basically overdoing it. so i will run a wire from the underside of the mounting screws to the grounding block. more pictures to come soon i hope.
Chuck ![]() |
#78 |
oh yeah the wires then all get pushed behind that metal panel that the visors hang from
Chuck ![]() |
#79 |
![]() Join Date: Jan 2012
Awesome job was your rear upper hatch in good shape or did you have to rebuild it? I am not real computer savoy yet to be able to do a build thread , but I am wanting to try and start one. I too am really interested in the 4bt swap and how it goes in and how well it works for such a big truck. I just bought mine this past January and I have been physically and now financially banged up. So right now mine is a survivor driver! I love driving it every where. Can't wait to see the finished project. Did you do the paint your self? Did you figure out where or how the water gets down all of the door pillars and vents? How did you seal your's up? Those are the kind of things I am needing to figure out? Any help?
#80 |
Chevy Enthusiast
Wow that 4BT looks good in there, I like the gas cap too!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#81 |
The hatch was in pretty good shape. Never rusted through but rust falling out of the weep holes and you could hear it rattle everytime the hatch as opened or closed. I had it cut open and cleaned up and coated then I re sealed it with tank sealer.
I found the other weep holes and blew them our with a compressor. I had the rocker areas rust sealed the other areas were fine as the rig was garages most of it's life. Aside from the tailgate I only had rust in a small patch on the passenger floorboard and it was only some light surface rust. Oh yeah I had it painted at a body shop one I wouldn't recommend. Not because the paint but because the management. Posted via Mobile Device
Chuck ![]() |
#82 |
Thanks for the comments. Hope to be back at it next week. Maybe I'll have some new developments
Chuck ![]() |
#83 |
What did you source your 4bt out of? Is there another build page on here that shows more of the transplant into the burb? I love the idea of a 4bt, I have been looking to put one in my 64K10 short bed. I have had a hard time finding a good used 4bt out of a truck. Is yours from a tractor or piece of equipment? What did you have to do to make it work properly for your application? Where did you source your conversion parts from? How well does your 4bt work in your burb as an everyday driver? Love the whole build!
#84 |
we found it in some warehouse in california, from the bread trucks.
this is my build thread, it is still not complete but i hope to have some pics of the new mounts and hopefully any other progress. I have a diesel mech/machinist doing the install for me. He has done twenty some conversions.
Chuck ![]() |
#85 |
Resident of Here
Subscribed! Absolutely love it!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#86 |
Tested the electrical for the first time almost one year after i made my first connection.
it had a ghost but quickly went away when i shorted the courtesy light.
Chuck ![]() Last edited by Coboyle04; 08-09-2012 at 02:20 PM. |
#87 |
gauges working and the radio too.
anyone know how to reset the odometer? or maybe a good quality replacement.
Chuck ![]() |
#88 |
more parts
Chuck ![]() |
#89 |
i must say i am very thankful for the grounding kit!
Chuck ![]() |
#90 |
Ridin' Dirty
can't wait to see more!
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
#91 |
Just a nother gear head
You could probably pull it apart and turn the dials to zero. i did it to one i replaced in an 84 c10 i had. wasnt to hard IIRC.
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 ![]() |
#92 |
My wiring harness has an accessory harness with the 2x20amp lines, 3x30 amp lines
wired into the fuse panel. all are 12 volt and either off battery or ignition how much or what can i supply with a 20 or 30 amp fused line? want to eventually add rear aux heater, rear aux power (cig lighters), maybe some rear bumper lights, air compressor....maybe some rear A/C
Chuck ![]() |
#93 | |
I had a V-8
I'm really diggin your Suburban. Very nice work on it!! You are going to have a sweet truck when it gets finished!!
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
#94 |
![]() Join Date: Aug 2005
Well done chuck. Watching from Hillsboro
#95 |
Hey thanks man! Are you the one who does the "Tahoe" conversions? Big fan!
Chuck ![]() |
#96 |
That's me (doing one). It will come out of hibernation when the Minx is done.
By the way, I'd vote for two rows of buddy buckets. That's the sweet setup on burbs/tahoes ![]() |
#97 |
![]() Join Date: Aug 2007
Looking good Chuck, nice to see it coming along so well. Dont you just love the $$ pit
Scotts72C10 |
#98 |
![]() Join Date: Feb 2004
What a job! Looks great.
Posted via Mobile Device |
#99 |
well we are finally making some progress.....its slow but it is still progress.
mounting the rear sway bar, fuel lines and pump, mounting e-brake cable, transmission mounts
Chuck ![]() |
#100 |
fabricated motor mounts
Chuck ![]() |
