Old 06-19-2012, 09:27 PM   #1
CigarMan
Attaching Sway bar to CPP control arms
Well I have a nice 1 1/4 bar that will not mount to single hole lower arm. Any ideas on how a can make this work without buying CPP sway bar?
CigarMan is offline   Reply With Quote
Old 06-20-2012, 03:58 PM   #2
CigarMan
Re: Attaching Sway bar to CPP control arms
No one has any idea on this? I noticed that the cpp sway bar is flattened on the end which is where they drilled single hole for mounting to sway bar. Maybe I can just drill hole throught this bar..
Old 06-20-2012, 04:31 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
You'll have to either fabricate and weld a tab to the LCAs for the bushing mount, or (and I would recommend this) run the newer style sway bar.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
