07-12-2012, 09:38 PM | #51 |
Re: Duramax/cummins conversions?
It would be a Cummins 6BT non-intercooled and VE pump. The non-intercooled actually put out more power than the later intercooled versions due to larger injectors.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
07-12-2012, 09:39 PM | #52 |
I found one for 2k is it worth that? It says runs but the tranny went out in the truck. 2k for the motor or 3500 for the whole thing
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
07-12-2012, 09:41 PM | #53 |
2k is good for a Cummins at least for around here. And for 3500 i would just buy the whole thing and part it out.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
07-12-2012, 09:44 PM | #54 |
It says it's a d250 with a 9ft flat bed dual rears with a cummins. It says 95k miles but real mileage unknown.
07-12-2012, 09:48 PM | #55 |
$2k would be OK if you can confirm it really only has 95k and not 495k.
07-12-2012, 09:51 PM | #56 | |
07-12-2012, 09:53 PM | #57 |
That sucks.
07-12-2012, 09:54 PM | #58 |
It wasn't a big deal it was still a solid truck and I'm guna change motors anyways
07-12-2012, 09:56 PM | #59 |
Oh I thought you meant a daily driver/ non-project.
07-12-2012, 10:01 PM | #60 |
Bring a compression gauge and see if the owner will let you test it. If not, that'll indicate that it has a lot more miles than he claims.
07-12-2012, 10:10 PM | #61 |
http://charlotte.craigslist.org/pts/3125755086.html that's the link to the cummins I'm going to pass on it I think I would rather do a dmax even though it harder and more expensive I haven't seen a completed one yet.
07-12-2012, 11:18 PM | #62 |
I found a place that sells Wrecked/totaled cars and trucks and they have a few duramaxs ranging for like 1000-4000$ i think im going to give them a call in the morning and see what all they have
07-13-2012, 12:23 AM | #63 |
that's like a professional football team wearing a fairy outfit
"As I walk through the valley of rice i fear no honda, for i have torque!" |
07-13-2012, 12:25 AM | #64 |
double post
lots of complicated wiring is going to be involved, but would still be cool as an eskimo
07-13-2012, 12:26 AM | #65 |
07-13-2012, 08:36 AM | #66 | |
07-25-2013, 11:33 PM | #67 | |
All you need to do to run an Alison trans behind a cummins is change the bell housing from the stock one to a SAE bell housing. Cummins engines and all other diesel engines will have a SAE bolt pattern on the block. Posted via Mobile Device Posted via Mobile Device |
07-26-2013, 12:14 AM | #68 |
At the body shop.
Why? Its an International engine
" That didnt make it any newer " " Dont antique the equipment " |
07-26-2013, 01:30 AM | #69 |
isuzu the ford engines are internationals
"DON'T TOUCH THE TRIM!!"-Early Kyler |
07-26-2013, 05:06 PM | #70 |
I'm in the process of building a 12 valve/6 speed allison truck. Getting the chassis about wrapped up so I can set the can and bed on and start hooking things up. Used a Destroked adapter to hook the ally up to the cummins.
http://67-72chevytrucks.com/vboard/s...d.php?t=588707 |
09-26-2013, 11:33 AM | #71 |
I didn't see where this has been mentioned yet but there are a few companies that make stand alone wiring harnesses for Duramax conversion. I think you just have to send in the old harness and they do the rest.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
09-27-2013, 08:37 AM | #72 | |
Not any more than a cummins, Or Isuzu's Duramax. The 7.3 was produced by International/Navistar, not Ford. Really you should be saying that about the Duramaxs' they come with cause at least International is an american company |
09-27-2013, 11:22 AM | #73 |
Pacific Performance Engineering (I think?) will do just that. From what I was told, you can send them a hardness from your engine and they will basically modify it so that you feed power to it, and have a wire for the ignition to start.
09-27-2013, 12:24 PM | #74 | |
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
09-27-2013, 03:07 PM | #75 | |
http://www.btdieselworks.com/product...wiring-harness
