Old 07-11-2012, 07:02 PM   #1
82ccshorty
82ccshorty's Avatar
Duramax/cummins conversions?
Are there any Duramax or cummins conversion threads on here or anywhere? i am thinking about doing a duramax in my 82 crew cab and im wondering how hard its going to be. I want inputs on each one too. cause i would do a cummins if its a easier/cheaper swap
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 07-11-2012, 07:06 PM   #2
badpontiacs
badpontiacs's Avatar
Re: Duramax/cummins conversions?
I'd keep it GM. Cummins is easier but I like a challenge.
badpontiacs is offline   Reply With Quote
Old 07-11-2012, 07:16 PM   #3
GW72C20
Cummins would be easier/cheaper. Here's a thread where a guy did a 5.9 swap in a 95 chevy.
I'd love to put an LBZ in somethin but the cost alone keeps me from it. Not to mention the headache.
GW72C20 is offline   Reply With Quote
Old 07-11-2012, 07:23 PM   #4
kwin
kwin's Avatar
The issue other than cost and complexity is the cummins will outlast the duramax probably by at least five fold.
Most trucks up here ( 3/4 and up ) are diesels you can find duramaxs with 250- 300 thousand k but I know several guys with 12 valve cummins with over 650xxx don't think you will see many d-maxes with that kind of mileage.
Don't get me wrong I love the Duramax but its a different animal , you almost cant compare.
Keith
kwin is offline   Reply With Quote
Old 07-11-2012, 07:24 PM   #5
Monty
here is a duramax '72 2wd suburban build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=472138
Monty is offline   Reply With Quote
Old 07-11-2012, 08:01 PM   #6
82ccshorty
82ccshorty's Avatar
Thanks guys. i think im guna look into prices i would like to find a donor truck for either one because i beleive i could come out cheaper that way since i will need wiring harnesses and trannys and all that stuff
Old 07-11-2012, 08:47 PM   #7
Car'n'Guitars
Car'n'Guitars's Avatar
If you go the Cummins route shy away from the 24v.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 07-11-2012, 08:48 PM   #8
82ccshorty
82ccshorty's Avatar
Why do you say that?
Old 07-11-2012, 08:50 PM   #9
Car'n'Guitars
The heads and blocks on the 24v Cummins have a cracking problem, there was a lawsuit over it.
Old 07-11-2012, 08:54 PM   #10
82ccshorty
82ccshorty's Avatar
Allght thanks for that.
Old 07-11-2012, 08:58 PM   #11
Car'n'Guitars
But the 12v Cummins are an awesome engine, very powerful and don't struggle with heavy loads.
Old 07-11-2012, 08:59 PM   #12
82ccshorty
82ccshorty's Avatar
I won't be towing much with it I just wanted something different
Old 07-11-2012, 09:01 PM   #13
Car'n'Guitars
Oh and they have great fuel mileage. We have one in our 97 Dodge and it is a great motor, definitely worth the money. I can't really vouch for the Duramax because I personally have not dealt with one, but either way you go it will be good.
Old 07-11-2012, 09:03 PM   #14
82ccshorty
82ccshorty's Avatar
I have a 2002 duramax and the only problem I have had with it is the injectors but my grandfather has a 2004 and it hasn't had any problems but to me it don't have the power the 2002 does
Old 07-11-2012, 09:05 PM   #15
WarBeard
WarBeard's Avatar
D-max belongs in a Isuzu. Cummins belongs in Trucks!
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 07-11-2012, 09:05 PM   #16
Goldfinger
Goldfinger's Avatar
As i recall there was a man doing a duramax/allison swap on this forums.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 07-11-2012, 09:08 PM   #17
Goldfinger
Goldfinger's Avatar
http://www.lonniesperformance.com/82chevyduramax.htm
found the link
Old 07-11-2012, 09:08 PM   #18
Edahall
Duramax Advantages:
Quieter
Lighter weight and not so tall
Allison automatic can be used behind it
Duramax Disadvantages:
Conversion is much more difficult
Initial cost will probably be more to buy a Duramax/Allison combo
Parts are more expensive
Expensive injectors are failure prone
Hard to get very good fuel economy
Cummins Advantages
12 valve has no electronics to deal with so conversion is much easier
Cheaper to make lots of power (P-Pump)
Better fuel economy
Parts are less expensive
No failure prone items
Can be used in front of a 6 speed NV5600 manual transmission
Cummins Disadvantages
Heavier and taller
Automatic transmissions that go behind them are failure prone
Hard on automatic transmissions
Noisier especially with the P-Pump (94-98)
VE pump (88-93) is only good for 450 hp vs 1000 hp for P-Pump
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 07-11-2012, 09:09 PM   #19
82ccshorty
82ccshorty's Avatar
Yes I read that whole thing he done some weird things in my opionion like the body lift instead of cutting the floor and things like that
Old 07-11-2012, 09:10 PM   #20
Car'n'Guitars
Also you can run a Allison trans with the Cummins, but I don't remember the exact trans model.
Old 07-11-2012, 09:11 PM   #21
Edahall
Something different would be a 7.3 Powerstroke.
Old 07-11-2012, 09:11 PM   #22
82ccshorty
82ccshorty's Avatar
Thumbs down Re: Duramax/cummins conversions?
Originally Posted by Edahall View Post
Duramax Advantages:
Quieter
Cummins Advantages
Better fuel economy
Heavier and taller
As much as I like the duramax it is like you said ex
Old 07-11-2012, 09:14 PM   #23
82ccshorty
82ccshorty's Avatar
Duramax Advantages:
Quieter
Cummins Advantages
Better fuel economy
Heavier and taller
I agree on what you say and the Trans problem on the cummins is a easy fix with a sun coast Trans but I like the duramax because I have one and I know how good they run. And I deffinatly want a autotrans because it's going to be a daily driver
Old 07-11-2012, 09:14 PM   #24
Car'n'Guitars
Yeah the early 12v Cummins can make a lot of power no problem.
Old 07-11-2012, 09:17 PM   #25
82ccshorty
82ccshorty's Avatar
That would be different but very wrong for a Chevy
