Old 07-19-2012, 01:28 PM   #101
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: 1958 LS2 with C4 front and rear
Originally Posted by dug224 View Post
Very nice. Just discovered your thread and had to subscribe. Will be watching your wiring work especially close since it is not too far off for me.
I am not very versed in LS setups but give me a couple of weeks.......lol
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 07-20-2012, 08:54 AM   #102
ricott
I sent you a PM regarding some of your "Take Off" parts from this project.
ricott is offline   Reply With Quote
Old 07-25-2012, 10:20 AM   #103
wutnxt
Anyone know where to get the aftermarket carpet piece that trims the carpet along the top of the inside step. I saw a truck with one on it and really liked it and would like to find them.....it's some kind of hard plastic trim that rings the edge of the step and carpet...
Old 09-01-2012, 10:07 AM   #104
wutnxt
Well....
I haven't done many updates lately but i sure have done a ton of work ....I have 3 full truck builds in progress....but updates as follows...
Old 09-01-2012, 02:03 PM   #105
wutnxt
Well I got all the parts for the bed at long last.....it wasn't pretty tey shipped a short box step side instead of the fleetside....Apparently if you need afleetside kit they have to be made the manfacturer doesn't stock them....anyway I got it and stained.....
Old 09-01-2012, 02:05 PM   #106
wutnxt
It was the stainless strips that took so long to get....but it managed to work it's way into the truck....
Old 09-01-2012, 02:08 PM   #107
wutnxt
Well the gas tank filler was a .....expierence....When e welded the filler tube section in place it moved from the heat and made things really difficult. But with some time and a good game plan we managed to get it finished and it really looks clean.
Old 09-01-2012, 02:10 PM   #108
wutnxt
Drive shaft has been shortened and is in....Fuel lines are in...tranny lines are in....shifter is hooked up....brakes are bled....air system is pretty much buttoned up...battery wire set up is done......it's getting closer every day
Old 09-01-2012, 02:12 PM   #109
wutnxt
swapped out the intake for the corvette intake....not a huge job went easy once i could find some itake bolts fr the intake. After looking everywhere after markey ARP and whamo.....
Old 09-01-2012, 02:13 PM   #110
wutnxt
Oh and but the way the trailblazer intake bolts not even close.....and the injectors don't swap over either.....
Old 09-01-2012, 02:16 PM   #111
wutnxt
Well....
Started opening up the harness and taking out what we don't need...For a old school guy like me this LS stuff sure has alot of wires. But hey it's sink or swim time so we dove right into it....
Old 09-01-2012, 02:20 PM   #112
wutnxt
The main harness is on the engine....still have some change to make yet...One section of harness left to take apart but i am hopefull that we have it all figure out. I am nervous don't get me wrong but we are a couple of days working on it away from trying to fire it for the first time.....crosses my fingers.
Old 09-01-2012, 02:21 PM   #113
wutnxt
Oh and some kind of spacer on the front of the intake to bolt on the air flow......yea i know but how hard can that be right ?
Old 09-01-2012, 04:25 PM   #114
Kim57
Kim57's Avatar
Looks like you're getting real close. The bed looks great.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-02-2012, 12:05 PM   #115
Larry Lindley
Great build and lots of info did you use stainless to make the top radiator hose connector,on my project I had a stand alone harness made,the EFI is all new to me,keep up the good work.
Larry Lindley is offline   Reply With Quote
Old 09-03-2012, 12:01 AM   #116
Lolyin58
Lolyin58's Avatar
Looking great, now hurry up and get it running. Gonna be sweet!!!!
Lolyin58 is offline   Reply With Quote
Old 09-03-2012, 08:59 AM   #117
wutnxt
Kim
Hey thanks...
It's the first kit I have ever used, usually I would start with rough oak and run and make it ll custom.....this way sure was faster but it comes with it's own issues.
Old 09-03-2012, 09:01 AM   #118
wutnxt
Yea both the upper and lower rad hoses are stainless and custom fit. There is a small piece of rubber hose at each end that is basically heat shrinked onto finish it off. It was just too tight for a rubber rad hose.
Old 09-03-2012, 09:03 AM   #119
wutnxt
I am trying........I am tryinggggggggggggggggg......This build has certainly not been the easiest. It's just a fight the entire way but am in the home stretch now.
Old 09-03-2012, 11:58 AM   #120
_Ogre
_Ogre's Avatar
dang, your truck is looking good
wiring looks scary enough
shop air compressor timer
Old 09-03-2012, 01:59 PM   #121
wutnxt
Ogre
Thanks man...yea there is some wire there for sure
Old 09-04-2012, 03:00 PM   #122
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Hey buddy, it's looking great! Shouldn't be long now. Good luck!
Ryan
1969 Chevy milk truck
Old 09-04-2012, 08:17 PM   #123
99 to Life
99 to Life's Avatar
looks great, have fun with the wiring. I'd def go with an expensive aftermarket harness. I was thinking of this route for a future project, def not looking forward to the wiring on it though, sensor this, sensor that. luv the truck though
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 09-05-2012, 09:25 AM   #124
wutnxt
Thanks....
I sure hope so....this build was way bigger then it was going to be when it started...
Old 09-05-2012, 09:34 AM   #125
wutnxt
Well i guess we will see....I should be turning the key soon...We found a guy who is going to tune the computer and set it up. Just waiting on him at this point
