Old 07-22-2012, 02:24 PM   #1
smartass12
smartass12's Avatar
A little HELP!! from dropmember guys please.
I obvioustly screwed things up..look where my dif lines up in my notch when the trailing arms are installed. Can i just move the trailing arm crossmember forward to fix this or am i screwed??
second bit of help needed. I cant seem to find hardware in my kit to mount the upper and lower control arms. this is all the hardware i have left other than miscellaneous nuts and bolts (nothing i have left seems correct for installation). Does the uppers mount (flat side if pivot, for lack of better words) dirrectly to dropmember with just bolt/nut? Also was i to use something off my old lower control arms to mount the new ones?? the rod/nuts in nates instructions are no where to be found and wasnt sure i had to use something off my old setup?
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
Old 07-22-2012, 02:49 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: A little HELP!! from dropmember guys please.
Swing your trailing arms all the way up.
Where does the rearend hit inside the step notch?
Keith
Convert to disc brakes.
Old 07-22-2012, 02:57 PM   #3
smartass12
smartass12's Avatar
meaning drop the truck on its frame to see where the dif hits in the notch when slammed?? sorry just not sure exactly what u mean by that(im not to smart)
Old 07-22-2012, 06:20 PM   #4
lolife99
lolife99's Avatar
yes
Keith
Old 07-23-2012, 07:09 AM   #5
andrewmp6
The trailing arms travel in a arch so when its lowered the rear end is kinda pulled foward some.On the hardware just wait for nate or dave to wake up they will chime in asap.
Old 07-23-2012, 09:44 AM   #6
smartass12
smartass12's Avatar
That is what i assumed as well. right now its on jacks about 10-12 inches off the ground..as soon as i start dropping it im sure it will come in contact with the notch.
Old 07-23-2012, 10:09 AM   #7
canadian trucker
A day should have 30 hours.
Do you have a further away picture of your rear setup?
Something looks "off" in the picture.
canadian trucker is offline   Reply With Quote
Old 07-23-2012, 10:30 AM   #8
smartass12
smartass12's Avatar
Old 07-23-2012, 12:00 PM   #9
Jparks
Jparks's Avatar
your notch looks to be in about the same place as mine was at that point, I think like someone mentioned earlier, drop it down (or jack the rear end up) and see if the problem still exists
Jparks is offline   Reply With Quote
Old 07-23-2012, 12:03 PM   #10
smartass12
smartass12's Avatar
I'm going to drop it down this afternoon hopefully and see what it looks like then, I just think it's going to push it further back
Old 07-23-2012, 12:09 PM   #11
lolife99
lolife99's Avatar
Just stick a floor jack under the rearend and raise it all the way up.
Keith
Old 07-23-2012, 02:00 PM   #12
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Also, the trailing arm should have a heim joint where it attaches to the crossmember. You should be able to adjust that too, if you haven't already.
I think once you "lift" that rearend closer to the notch you'll be fine.
And maybe mock up the lower bag mounts and make sure they line up with the uppers...
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 07-23-2012, 04:08 PM   #13
PBFAB.COM
PBFAB.COM's Avatar
Send me your e-mail address and we will send you a set of instructions.
There is almost an inch and a half difference in the rear wheel well opening center-line on the Fleet vs. Step side trucks. The stepper is forward when compared to the fleet. We also make a notch specifically for the step side beds now, and If I recall correctly, you have a step side bed... and we sent you the new step side notch.
You should have left your trailing arm cross-member in the forward most mounting position so that the axle lands in the center of the notch/center of the wheel well opening. Should be a simple fix. Go ahead and give us a call with any questions so we can get ya fixed up.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-23-2012, 04:59 PM   #14
project 67 sub
project 67 sub's Avatar
^^ customer service at its finest right their
will continue to do business with this guy when i can...
project 67 sub is offline   Reply With Quote
Old 07-23-2012, 05:24 PM   #15
502ms
502ms's Avatar
Nice! You guys rock! I'm going to find a Burban so I can DM it
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 07-23-2012, 05:30 PM   #16
project 67 sub
so the dropmember bug is still biting you huh Leon
Old 07-23-2012, 05:43 PM   #17
lolife99
lolife99's Avatar
x2
Keith
Old 07-23-2012, 06:05 PM   #18
smartass12
smartass12's Avatar
Nate
Thanks for the response nate. I did already get the email with instructions. So the cross member should be mounted as far forward (towards front of truck) for the stepside to center? I guess my screw up was mounting it towards the rear of the truck per instructions but that must be for fleet side. Pretty quick fix if that is the case.
Old 07-23-2012, 06:42 PM   #19
PBFAB.COM
PBFAB.COM's Avatar
I might have sent you an earlier version of the instructions where I didn't have the step side location referenced for the trailing arm x-member.
Let us know if you have any more questions. Your brake kit should be shipping from CPP today or tomorrow.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-23-2012, 07:26 PM   #20
smartass12
smartass12's Avatar
Nate
You are truly the MAN!! The only other thing i cant find is the hardware to mount the new lower control arms, i found the bushings but thats it..was i suppose to use stuff off my old ones? Also, I need to give dave a call a put together another order.
Old 07-23-2012, 07:38 PM   #21
PBFAB.COM
PBFAB.COM's Avatar
Lower control arms mount like so:
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-23-2012, 07:39 PM   #22
PBFAB.COM
PBFAB.COM's Avatar
There should have been upper control arm hardware supplied in your kit as well. Give us a buzz and we can make sure you get what you need.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-23-2012, 08:08 PM   #23
smartass12
smartass12's Avatar
Thats what those were for..On the instructions i got it was showing a rod of some sort..My bad, i have those pieces..all is good..Thanks again for your awesome product and customer service.. Being a business owner myself i can say you completely know how to take care of business.
