Old 09-09-2012, 03:51 PM   #26
parkwood
parkwood's Avatar
Re: MII front suspension-brake line
Originally Posted by shadow1967 View Post
Theres about 3/8" gap between the frame an air shock.
Ok thats good, as you know just make sure the bag doesn't hit anything after you get it aired up and under load.. Wouldn't want anything to happen to you or the car..
parkwood is offline   Reply With Quote
Old 09-09-2012, 09:07 PM   #27
shadow1967
shadow1967's Avatar
Parkwood,
Do you have any front shots of this car? You have that sway bar up there tight. I like!
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 09-09-2012, 11:54 PM   #28
parkwood
parkwood's Avatar
I don't have any good shots on this truck of the sway bar but i've got some shots from another car that i can show..
All most all the front x-members i use are from TCI and have a place to bolt on the sway bar and keep it tucked up tight...
These are some off a '52 suburban using air bags but the sway bar bolts up the same on air or springs..the one with the motor shot from under is the truck you're asking about.. only good i have that you haven't seen.
Old 09-10-2012, 12:02 AM   #29
parkwood
parkwood's Avatar
This cross member didn't have a place for the sway bar to bolt to so i had to add the corners, but it came out like all the rest.. this just shows you a better view of how it bolts up..
Old 09-10-2012, 07:51 PM   #30
shadow1967
shadow1967's Avatar
Parkwood,
Thanks for the pics. Dad especially liked the old school scissors jack.
Old 09-10-2012, 08:05 PM   #31
parkwood
parkwood's Avatar
Parkwood,
You're welcome, hope they helped you.. Tell your dad the old jack had been around my garage for over 35 years...
Old 09-10-2012, 08:37 PM   #32
Rude Dude
Rude Dude's Avatar
Here is how I ran my lines
Rude Dude is offline   Reply With Quote
