Old 08-31-2012, 08:26 PM   #1
shadow1967
shadow1967's Avatar
MII front suspension-brake line
Guys with MII style front suspension. How did you guys run the brake line from the master cylinder to driver front then to passenger front? I'm more interested in the one you made to cross from drivers to passengers side. Thanks in advance!
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 09-01-2012, 01:58 AM   #2
parkwood
parkwood's Avatar
Re: MII front suspension-brake line
Hope these help you, these are from different cars some using FatMan front ends and TCI front ends.. but the brake lines don't know the difference.
I thought i had some better pictures but i don't..
parkwood is offline   Reply With Quote
Old 09-01-2012, 12:41 PM   #3
Highsider
Highsider's Avatar
Awesome photos, parkwood!
Highsider is offline   Reply With Quote
Old 09-01-2012, 01:14 PM   #4
_Ogre
_Ogre's Avatar
more or less like parkwood did
no pics to show though
shop air compressor timer
Old 09-01-2012, 06:06 PM   #5
shadow1967
shadow1967's Avatar
Thats what I needed to know. Back side of crossmember works. Thanks Guys!
Old 09-05-2012, 02:30 AM   #6
parkwood
parkwood's Avatar
Found a few more.....
Old 09-05-2012, 10:03 AM   #7
Highsider
Highsider's Avatar
Mr. parkwood-
Please explain what this photo is showing me. Some sort of adjustment knob for the rear axle's fluid? (I thought I was fairly knowledgeable) Thx!
Old 09-05-2012, 12:35 PM   #8
youngrodder
youngrodder's Avatar
Highsider-
I can help you. Parkwood (Wayne) is probably busy building awesome streetrods...
You are correct. It is a way to adjus the pressure to the rear brakes. I used one on my truck as well. Here is a pretty good explination that I found.
"A Proportioning Valve is installed in the rear brake line and allows you to adjust the rate of pressure rise to the back brakes. With an adjustable proportioning valve, you can slow down the pressure rise that occurs when you apply the brakes. Under braking, most vehicles transfer more weight to the front wheels. When this happens, the rear wheels lose some weight and can lock up if the pressure is too great too quickly in the braking process. Eventually full pressure is applied to the rear brakes through the proportioning valve."
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 09-05-2012, 12:36 PM   #9
Kabwe
Certified Car Nut
Kabwe's Avatar
Originally Posted by Highsider View Post
Mr. parkwood-
That is an adjustable proportioning valve. It allows you to slow down the pressure rise that occurs when you apply the rear brakes. When braking, more weight is transferred to the front which can cause the rear brakes to lock up if it gets pressure to fast. Thus adjustable proportioning valve.
Kabwe is offline   Reply With Quote
Old 09-05-2012, 12:42 PM   #10
parkwood
parkwood's Avatar
Thanks guys, i could have said it better myself..........
And hope we've helped another hot rodder...
Old 09-05-2012, 03:58 PM   #11
Highsider
Highsider's Avatar
Thanks, guys! Now I have to go look to see if my ride has one.
In 300 miles of driving it, I haven't skidded the rear....yet. hahaha!
Old 09-05-2012, 05:54 PM   #12
57halfton
Parkwood check your private messages please.
Gene
57halfton is offline   Reply With Quote
Old 09-06-2012, 01:05 AM   #13
parkwood
parkwood's Avatar
Gene
got it and sent one back...
Old 09-06-2012, 02:00 PM   #14
57halfton
Parkwood , my PM's must not be working , didn't get any new PM's.
Do you have that crossmember ?
Gene
Old 09-06-2012, 03:13 PM   #15
solidaxel
solidaxel's Avatar
Yes you did, now tell us how to adjust it for Camaro drum brakes on a AD with the bed empty?
I have done many test on a dirt road trying to find the right number of turns, so far still testing..................daily on dry pavement !!
Where did you start and where is it today?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-06-2012, 06:03 PM   #16
parkwood
parkwood's Avatar
Gene
check again, sent another one... if that doesn't work i'll send up a smoke signal..
Old 09-07-2012, 11:48 AM   #17
youngrodder
I have never really adjusted mine. I'm using a 4 wheel disc brake set up with a camero booster. I turned the dial to the center and my truck stops really good, so I have never even adjusted it.
Maybe I got lucky.
Marc
Old 09-07-2012, 05:47 PM   #18
Kabwe
Certified Car Nut
Kabwe's Avatar
Parkwood or anyone who has,
Have you ever used the brake line Thru-Frame Fittings? If so whats your experience with them. I never used them but I've been thinking about it because it looks to make for a really clean install.
Old 09-07-2012, 06:31 PM   #19
parkwood
parkwood's Avatar
Kabwe, i've used them on my Hot Rods (early Fords) the main thing i've found is make sure you drill a straight hole or they will not lay flat.. and you use AN fittings on the side going to the brakes.. the inside you can put adapters in for AN or use normal brake lines.. with an adapter... i'll see if i have pictures some where..
wayne
Old 09-07-2012, 06:42 PM   #20
Kabwe
Certified Car Nut
Kabwe's Avatar
Did you like them? Any problems with leaks?
Old 09-07-2012, 09:00 PM   #21
parkwood
parkwood's Avatar
No, no leaks as long as you tighten them down... they clean up where the brake lines come through the frame and look like you took time to make it look nice.. I'm not sure what they cost but i don't think they are giving them away..
here is what they look like on my '33 coupe..
Old 09-07-2012, 11:13 PM   #22
Kabwe
Certified Car Nut
Kabwe's Avatar
That looks clean. They are about 50 bucks for a set and I don't mind spending money on things like that because I love attention to detail items. It looks like you tee off the one on the driver side is that correct. If so I like that.
Thanks for the information.
Old 09-08-2012, 09:41 PM   #23
shadow1967
shadow1967's Avatar
Yes theres a tee on drivers side and a 90* passenger side. Thanks for everyone's input. And here is what we came up with. We didn't want the tee or 90* sticking out to far from the frame, so dad recessed them back a little. Thanks again, SORRY for the delay.
Old 09-08-2012, 11:06 PM   #24
parkwood
parkwood's Avatar
Just a quick question, It looks like your shock wave air bag is hitting the frame or am i see it from the wrong angle???
Old 09-09-2012, 01:21 PM   #25
shadow1967
shadow1967's Avatar
Theres about 3/8" gap between the frame an air shock.
