09-26-2012, 01:45 PM | #26 |
Re: Tweaked Frame
I still have a scar from an unguarded cut off wheel incident, took a year or so for my finger to work normally
1966 C10 250 with 3 on the tree Build Thread Bunch of other cars no one cares about |
09-26-2012, 02:36 PM | #27 |
Newbee
Re: Tweaked Frame
[QUOTE= After shooting a 7" grinding disc across the shop years ago due to inappropriate use, then having to spend a week fixing collateral damage around the shop, I tend to have a lot of respect for spinning things.
I had the same problem with a stainless shrinking disc. It's amazing how much damage a 10'' spinning stainless disc can do. I also proved that I do have cat like reflexes |
09-26-2012, 06:25 PM | #28 | |
Re: Tweaked Frame
09-26-2012, 07:38 PM | #29 |
Re: Tweaked Frame
how about taking it to a frame shop and having it done rite ? took mine there and came back perfect, just my .02
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
09-26-2012, 07:53 PM | #30 |
Re: Tweaked Frame
Well, Arturo7 What's the plan. After reading the other posts I think I would make a relief cut where the metal stretched when it was bent or heat the stretched areas red hot and then straighten the frame horn out.
If you use the 4 or 4-1/2 inch cut off disks don't use the super thin ones as those are the ones that usually come apart when a guy is cutting something. I've had a lot better luck with the 1/16" 4-1/2 inch staying together then the .030 disks. Keep us posted on your progress and take a few photos of what and how you do it. |
09-26-2012, 11:44 PM | #31 |
Re: Tweaked Frame
[quote=Dunenutt;5613995][QUOTE= After shooting a 7" grinding disc across the shop years ago due to inappropriate use, then having to spend a week fixing collateral damage around the shop, I tend to have a lot of respect for spinning things.
I had the same problem with a stainless shrinking disc. It's amazing how much damage a 10'' spinning stainless disc can do. I also proved that I do have cat like reflexes[/quote] Those thing spin at 16-22K rpm. I wear a face shield and all the gouges are a testiment to how much stuff gets thrown around. I used to only use googles until I got a piece of wood embededed in my check from the table saw kicking back.
09-27-2012, 01:49 AM | #32 |
Re: Tweaked Frame
I believe I will try the notch and bend method. I stopped in at a frame shop and got a price of $95/hr with a two hour minimum. 190 bucks buys quite a few grinding wheels. Plenty to sail around the work area...
09-27-2012, 07:17 AM | #33 | ||
Re: Tweaked Frame
09-27-2012, 10:20 PM | #34 |
Re: Tweaked Frame
The measurement of frame should be 34 inches across outside to outside if looking at it straight a head, make a jig out of angle iron before you dice and slice. I would try a porter power on the frame against a beam or something solid like a tree with a little heat and what was said before relief cuts.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
10-11-2012, 08:27 PM | #35 |
Re: Tweaked Frame
So I had a frame guy take a look at it today.
He suggested I beat it with a sledge... |
10-11-2012, 11:47 PM | #36 |
Re: Tweaked Frame
better first buy a new tape measure and the assembly manual before you use a BFH on it. measure the frame and find out where the actual bend starts and mark it and write down how far it is over or under the measurement needed. getting reference point at the beginning is critical an in same direction always. Heat is your friend here and i have used my 18" cresent with heat having the helper running the torch also run the tape measure while i pull on bent area
10-12-2012, 12:26 AM | #37 |
Re: Tweaked Frame
Actually, the guy advised against using heat. He said it compromises the integrity of the steel.
On the bright side, I may have access to an hydraulic press. Not sure of the size, though. |
10-12-2012, 10:05 AM | #38 |
Re: Tweaked Frame
The steel in those frames is low carbon and heat wont hurt it. if it wter high carbon heat
will anneal it.making it soft. If the heat caused problems fram failures would be common around here! |
