![]() Join Date: Jul 2012
Tweaked Frame
Any ideas on how to address this?
Re: Tweaked Frame
The assembly manual has the dimensions at a ton of points:
http://chevy.oldcarmanualproject.com...51ctsm0202.htm See what it needs and where. Heat, BFH, pipe clamps should get you straight. |
Re: Tweaked Frame
I had some issues like that with my 52 3100 frame, at the rear. I used C-clamps, a Big (4 ft.) bar, BFH, pretty much everything I could think of that I had in my possession. I don't have a torch setup, but it would've been handy.
Patience and ingenuity... |
Re: Tweaked Frame
First you need to check if the frame is diamond. Which means if you cross measure from left front to right rear and vice versa the measurments should be same or damn close. Robin is correct that the assembly manual does contain the information of all those measurements. From just looking at it though it had been hit in the front at one time and probably just bent the frame rail there. Heat and BFH or even better, a come along and a big ass tree will get you there. Just dont pull too far!!
My '59 Build Thread |
Re: Tweaked Frame
MAAP gas, its the yellow one, with a propane head will get hotter if you don't have a welding torch.
Retired and too busy to work. |
#6 | |
Re: Tweaked Frame
measurements will have to be made back from the bend. Don't try to pull it back using the good side as an ancor or you could end up with both bent. I would cut small pie shaped notches in the top and bottom to weaken it enough to bend then weld it up when it is straight! The front crossmember is where the bend starts. I avoid big hammers if possable! every action has a equal reaction!often where you don't want it! |
#7 | |
Re: Tweaked Frame
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
Re: Tweaked Frame
Is that on the panel?
First I'd do as Wheelie suggested and make sure that the frame it's self is square. If the rest of it is square a few licks with a BIG sledge hammer might move that frame horn back in place. I'd somehow fasten a piece of steel plate to the side of the end of the frame horn to have a place to hit and not tweak up the horn with the hammer. Heat in the right spot where it was bent or a cut or two there to relieve it a bit won't hurt any but may not be necessary. Best case is if someone with a 58 or 59 that has the nose off can take a couple of straight on photos along with a few measurements to help you get it back square. |
#9 | |
Re: Tweaked Frame
![]() however when you hit your thumb with a hammer there is a multyplied reaction! ![]() Last edited by mknittle; 09-24-2012 at 08:48 PM. |
Re: Tweaked Frame
Thanks for the ideas, fellas. Y'all got me thinking...
Once the suspension is removed, I wonder if I could place a couple 4x4s against the outside of the frame horns extending back to the cab mounts, then squeeze it back into shape with a come along? I'm guessing this would not compromise the crossmember? |
Re: Tweaked Frame
If you remove the rad support bracket, then "V notch" the frame rail (top and bottom), clamp a bit of leverage to it, heat the rail, bend it into place and weld it like Sir Isaac wrote, you'll find it much easier and you won't damage any other areas by creating too much stress. Also, you won't buckle the upper and lower returns. In fact, you might not need to heat it. Just sayin'. PS; Don't make your "V" cuts any wider than you need. What ever route you go, Good luck.
#12 | |
Re: Tweaked Frame
#13 | |
Re: Tweaked Frame
1959 Fleetside Big Window Long Box Standard Trim soon to be Deluxe 1953 GMC Carryall Suburban |
#14 | |
Re: Tweaked Frame
#15 |
Re: Tweaked Frame
Yes It does work that way doesn't it!
#16 | |
Re: Tweaked Frame
4X4s are flexable enough that you may end Last edited by mknittle; 09-25-2012 at 10:01 AM. |
#17 |
Re: Tweaked Frame
Lots of good advice, I'll add by 2 cents. When I learned my bodywork the old timers first lesson was to just sit back and reconstruct what happened and where the metal had been modified and had tension. Then figure out how to release the tension and move the metal back into shape.
The other posters are right the metal stretch on the inside upper and lower flanges and that is where the tension is. If you just try and pull or bang it in the upper and lower horizontal flanges will buckle unless you shrink them by heating and heavy dolly work or the pie cuts and welding. Do not use the other parts of the truck for bracing, these are riveted together and designed to flex, you will just pull something else out of square. You also want to keep track of the spring shackle in that location so you do not pull the front axle out of square too.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#18 |
Re: Tweaked Frame
So, how do I make the cuts? Will I need a torch?
#19 |
![]() Join Date: Jul 2009
Re: Tweaked Frame
I'm not the expert these other guys are, but if it were me, I'd use a cutoff wheel. You'd get a straight cut where the edges should line back up for welding when you straighten the rail.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
#20 |
Re: Tweaked Frame
NO, cutoff wheel, hack saw, die grinder with this wheel, goal is to make a small cut, move, measure and if not enough, a little bigger, repeat as necessary. Also gives you a narrower weld to fill. I do not even own a torch to avoid such temptations.
#21 |
Re: Tweaked Frame
Thanks Orrie and rick for Your input.
Orrie is right about the torch! the only time I use one is for making bends in parts that i am making. I would use a cutoff wheel just because it makes a bit wider cut. |
#22 |
Re: Tweaked Frame
Reversing the damage, is that frame primarily bent toward the LH side of the truck, or is it bent up away from pavement? If it's bent up then the twist is a result of the upward displacement, a reaction if you will, and will reverse itself to some extent if the frame horn is forced down again. If the primary bend was in the direction of the LH side then you've got a bit more work ahead.
A well controlled sawzall or jigsaw with metal blades might get through that frame faster than a cutoff wheel if you end up at that point. |
#23 |
Re: Tweaked Frame
A cutoff wheel in a die gainder maybe. but one in a 4" grinder is way faster than a sawzall and dosen't hammer you to death.
I got out my sawzall a couple weeks ago I gave up after sawing/beating about an inch. Now I remember why it was in back on a bottom shelf. ![]() |
#24 | ||
Re: Tweaked Frame
#25 | |
Re: Tweaked Frame
