Old 11-20-2012, 12:21 PM   #1
tex_waco_usmc
Project Heaven in my 67!!!
Parting 71 LWB C10 BB 2WD
So things have changed again, and I have decided that instead of installing the BB in my 67 I am going to go the LS route eventually so I am parting this entire truck to try and put some money towards the motor that I want in the 67.
Truck is a factory BB truck with Air Conditioning...
The truck no longer has a bed or drivers side door on it...
So for starters I will post a few prices so as to keep inline with the rules... If you see something you need let me know and we can work something out. All prices are plus shipping and of course are always "or best offer", would rather not ship the big stuff but again we can work something out if need be...
402 BB - $700 no carb
TH400 w/yoke - $350
front 5 lug disc brake suspension - $150
Power steering Gearbox - $75
Power brake booster w/Master Cylinder and Prop valve - $50
cab w/title - $100 (needs outer rockers at a minimum most likely inners too)
5 lug rear axle - $150 (I dont know the ratio but will look into that tonight)
fiberglass rollpan for fleetside bed - $25
if you need better pics of anything just let me know...
Name:  71 lt side.jpg
Name:  71 rt side.jpg
tex_waco_usmc is offline   Reply With Quote
Old 11-20-2012, 12:35 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Parting 71 LWB C10 BB 2WD
Exhaust brackets that mount to the frame? Heat shield on pass side firewall? Trans linkage w/frame bracket and mount to tranny? Steering column? Frame brackets, clamshells, and rubber for engine?
Old 11-20-2012, 12:38 PM   #3
DaHos
DaHos's Avatar
2nd for the exhaust brackets, complete 2 pc driveshaft
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 11-20-2012, 12:39 PM   #4
MadnessBigBlock
prices on each of the following shipped to 58265.
-spark plug heat shields
-oil pressure line (from block to guage)
-power steering brackets, remote resivoir and hoses.
-crank, water pump, p/s pulleys
-Alternator brackets
-fan shroud
-rear sport bumper brackets
-passenger floor heat shield
Thanks, Brett.
MadnessBigBlock is offline   Reply With Quote
Old 11-20-2012, 12:41 PM   #5
tex_waco_usmc
Exhaust brackets that mount to the frame? Going to have to look to see if they are still there. The PO added aftermarket duals on this truck so not sure if they are still there
Heat shield on pass side firewall? will look tonight to see if it is in good shape, take pics for you and then we can discuss
Trans linkage w/frame bracket and mount to tranny? would like to leave with the transmission if trans doesnt sell soon then you will be first inline
Steering column? Non-Tilt Automatic in good shape will get some pics tonight for you I will take $40 plus the ride
Frame brackets, clamshells, and rubber for engine? Would like to leave with the engine for now, if engine doesnt sell soon then you will be first in line for them
Old 11-20-2012, 12:43 PM   #6
tex_waco_usmc
-fan shroud
Thanks, Brett.
Would like to leave the engine as complete as possible for now, will let you know if it doesnt sell like that
Truck had an aftermarket rollpan no bumper brackets
2nd inline for the heat shield, will look tonight to see if it is in good shape
Old 11-20-2012, 12:44 PM   #7
tex_waco_usmc
2nd inline for the exhaust brackets, still gotta look to see if they are still there
Old 11-20-2012, 01:31 PM   #8
BAT
If that rear end is a 12 bolt posi and you would be willing to put it on a skid, I would be interested in it. Also, any pics of the Brake Booster, etc.?
BAT is offline   Reply With Quote
Old 11-20-2012, 01:50 PM   #9
tex_waco_usmc
Not sure on the gear ratio, will know tonight! I will also get more pics uploaded tonight as well!
Old 11-20-2012, 02:03 PM   #10
specialtyretail
So,, what else you got???
specialtyretail's Avatar
We would give $100.00 shipped for the big block frame stands if no one has laid claim to them yet Thanks, Fred
specialtyretail is offline   Reply With Quote
Old 11-20-2012, 02:29 PM   #11
specialtyretail
Sorry, just read this whole post. Did not mean to cut in on anyone's deal...
Old 11-20-2012, 03:23 PM   #12
tex_waco_usmc
Here are some more pics and some that were requested...
Power Brake Booster
Name:  Power Brake Booster.jpg
Steering Column, someone messed with the turn signal lever... should be an easy fix, but works as is...
Name:  Steering Column.jpg
An original AM radio not sure of condition will attempt to see if it works later today $15 + shipping
Name:  AM Radio Front.jpg
Rear side of AM radio
The hangers are already gone or destroyed by the PO... Here is a shot of the rear of the frame
Name:  Rear Frame.jpg
More to come as I can get to it...
Old 11-20-2012, 03:44 PM   #13
DaHos
DaHos's Avatar
Any chance the small exhaust bracket on the pass side frame rail located just behind the trans xmember is still there?
Also are you interested in shipping the complete driveshaft, front and rear shafts with carrier bearing and xmember mount.
1967 C10 SWB
Old 11-20-2012, 03:49 PM   #14
tex_waco_usmc
To be honest I think that was the only hanger left. I will check again shortly and take a pic and make sure it is what you need. As far as the driveshaft you are second inline on it and I am up for shipping if you are willing to pay for it. The shaft is large so I am not sure what the shipping would be on it...
Old 11-20-2012, 03:55 PM   #15
DaHos
DaHos's Avatar
2nd on the exhaust brackets to(VA72C10), 1st on the driveshaft.
The shaft can be slipped apart at the splined slip joint.(JUST MARK BOTH SIDES FOR INDEX PRIOR TO REMOVAL). Should keep shipping reasonable.
I also see you listed the 400 yoke w the trans, I will need it.
LMK, thx, D'
1967 C10 SWB
Old 11-20-2012, 04:00 PM   #16
tex_waco_usmc
LMK, thx, D'
My fault got confused there for a second on the posts LMAO, yes you are first inline for the driveshaft but for now I would like the yoke to go with the transmission unless the person buying doesnt need it.
Old 11-20-2012, 05:06 PM   #17
kevmac
kevmac's Avatar
I can pick the rear end up in person if its avail and 3.08
kevmac is offline   Reply With Quote
Old 11-20-2012, 05:54 PM   #18
shawno72
C/10 junkie
shawno72's Avatar
How much for the center link with tie rods shipped to 95240 business addy?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 11-20-2012, 07:33 PM   #19
tex_waco_usmc
The rear axle is not positive traction, but I am not sure of the ratio... If anyone is still interested in it let me know!
Old 11-20-2012, 08:10 PM   #20
RatRod68
RatRod68's Avatar
interested in what is on the interior. How is the AC setup?
BTW, OOH RAH and happy belated birthday
build Threads:
Nasty 68 C10. My lil hotrod
Leftovers 68 C20
D-Ranged Ford Ranger on steroids
Semper Fi
RatRod68 is offline   Reply With Quote
Old 11-20-2012, 09:09 PM   #21
tex_waco_usmc
OOH RAH and Happy Belated Birthday to you as well! What were you looking for as far as interior and AC stuff?
Old 11-20-2012, 09:22 PM   #22
RatRod68
RatRod68's Avatar
depending on condition, I'd be interested in the whole A/c lot minus the metal dash and the compressor.
Interior wise, I'm interested in the A/c vents and controls. If you were local, I'd snag that seat from ya too, but shipping would kill me
build Threads:
Leftovers 68 C20
Semper Fi
Old 11-20-2012, 10:45 PM   #23
brian1971
brian1971's Avatar
Second in line for rear sport bumper brackets,how much shipped to 33315.thanks Brian
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 11-21-2012, 09:41 AM   #24
kevmac
kevmac's Avatar
still interested and can pick up this weekend but need to know the ratio, dont need the same as i have. thanx
Old 11-21-2012, 10:46 AM   #25
tex_waco_usmc
Gentleman, I will get pics and prices up today for those that have asked about parts.
