brake time for the 02 burb. need pad ideas
first time since we've owned it that the brakes will need to be done.
are all pads created equal for this beast? im looking at these for the front and these for the rear for about $80+ tax. |
![]() Join Date: Dec 2012
Re: brake time for the 02 burb. need pad ideas
If you buy at part store they usually have 3 grades always buy the BEST Money well spent If not go to dealer and buy oem There is a difference
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
as far as exact fit those look to be the best advance auto has to offer with good ratings. they are about $65 a set. then there is a $50 off coupon code to make them $80+ tax
but then again i can get these for the front and these for the rear for about $45 +tax
or the platinum version for about $60 +tax |
ok i talked to my mechanic and he said that if ceramic pads aren't recommended that he wouldn't suggest putting them on due to the squeaking affect it might cause.
so are ceramics ok to put on or the semi-metallic? |
Fabricate till you "puke"
I used the Wagner themo quiets on my o2 silverado, & am happy with the set
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
laying low
![]() Join Date: Mar 2001
I ran the Wagner Ceramics for years on my 97 Burb and loved them. Quiet and low dust emitting.
i too went the thermo quiet on my 02 1500hd front and rear. went thru 2 sets of annoying screeching with them. (the old brakes were silent just getting worn) Even with all new rotors, pads, clips, cleaned and greased properly they would be fine for about a week and a half then start screeching. finally made them warranty from the thermo quiets to perfect stops. Been alot happier with those than the thermo quiets.
