Old 01-10-2013, 07:33 PM   #1
sir_talk_alot
sir_talk_alot's Avatar
Best tire size for a 3/5 drop on rallys
So im wanting some opinions, im picking up a set of 6lug rally wheels tomorrow , and im trying to figure out the best tire size to put on them that dont look too small but dont rub. Truck has a 3 in front drop and if it ever quits RAINING/SNOWING ill put the back springs on. What are some suggestions for tire sizes. And also, for those wanting babymoons on their rally wheels, ive come up with an idea, rivet the tabs/clips like the old 50s trucks used to have to hold them on. Ill experiment and see what happens. Thanks guys in advance
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 01-10-2013, 09:07 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Best tire size for a 3/5 drop on rallys
There's a seller on E-Bay that sells the clips in a bolt on design.Only problem is he claims they're only compatable with the 5 lugs.
I'm running 225-70/15 and 255-70/15 on mine with a 2 1/2-4 drop.Using Rallies.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-10-2013, 11:38 PM   #3
sir_talk_alot
Got a few pics?
-Mike-
Old 01-11-2013, 12:10 PM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-11-2013, 02:01 PM   #5
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Although mine are five lug, the rally's are 15x8 with 275/15/60,s all four corners. 3-1/2" drop up front because 4-1/2" rubbed in the turns and bumps. 4" drop springs out back on a LWB 72 C-10 w/350/350tb...A 5" drop in the rear is going to require a "C-notch" in the frame, 4" is the limit. Hey paneldeland, you have a link for those clips?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-11-2013, 04:21 PM   #6
skorpioskorpio
Just out of curiosity where did it rub? I'm trying to spec out a build and I really want to do 295/45/18s at all 4 corners which are 1/2" taller than your 275/60/15s and an just under an inch wider. I was looking to do about a 3&4 drop. The rims I'm looking at have a 6.6" backspace (1.3" offset) so being too far out will not be the problem, if anything I'll need to do a spacer. Just looking to figure out where the problem areas are. Oh, BTW it's going to be a 4 corner Porterbuilt coilover build so some tweaking would be possible at build time. Also curious if the aftermarket front tubs from Hills Rod & Custom address this problem or are they really only for dealing with heavy dragger drops?
skorpioskorpio is offline   Reply With Quote
Old 01-11-2013, 07:26 PM   #7
sir_talk_alot
Im gonna rivet clips from an old 40s truck or car at 1.75 a piece they will look good and hold on caps
-Mike-
Old 01-11-2013, 07:30 PM   #8
leddzepp
Moderator
leddzepp's Avatar
215 70's on the front with 7" rallies. 275 60's on the back with 8" rallies. Gives it a nice rubber rake.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
