01-19-2013, 01:40 PM | #5801 |
Re : What did you do to your truck today!
You guys get so much done , it's inspiring .
I got the choke spring Flea-Bay links , thanx . My truck as always , runs O.K. for an old beat up piece of junk , I need to dip into the engine & swap out the cylinder head for the rebuilt one I have , maybe replace the piston rings , the pistons too if they're not good , replace the bad exhaust manifold , get & install a new choke thermostat , replace the failing aftermarket radio etc. , etc. Thing is I not only work slowly , I have serious physical limitations and , other vehicles are dead in the water so for now I just keep it full of oil and drive it.... The help and inspiration I get here , is priceless . Don , remember to ensure the ATF filler tube hole is Hospital clean and free of any overspray , don't use regular O-Ring , viton or other hydraulic fluid resistant is necessary else it'll soon begin to weep & wet the tranny. The yellow looks very nice indeed . I see you bought a High Torque starter , that's wise .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
01-19-2013, 01:40 PM | #5802 |
Re: What did you do to your truck today!
went and picked up some 030 wire and some new tips. now time to finish welding in the bed steaks
01-19-2013, 02:46 PM | #5803 |
put the fuel tank and seat back in it, changed the oil, and started it for the first time in 4 years. Ran great. Stopped very badly (is it bad when you have trouble stopping going up a hill at barely above idle speed?). Ordered brake parts.
01-19-2013, 05:39 PM | #5804 |
I installed new seat belts in my 71C20 due to one of the latches falling apart in my hands the other day
01-19-2013, 10:33 PM | #5805 |
I guess you could say "trucks"
you know after a swap meet or car show you allways get the itch too do something test fitted the bb an t400 I really just wanted too see if my 69 camaro headers would fit..... so far I think they fit great......but I wanna use a manual trans also helped an guided the kid on getting his timing chain replaced. its a lil' sloppy but I've seen worse. at least no nylon teeth were missing.theres a cloyes double roller going in its place.I wish it would stay as nice as it was today that would make it go a lil' better since its being done outside
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
01-19-2013, 10:34 PM | #5806 |
Nate glad you got the choke ordered, i really did not need to change my starter i had to , the old one bolted to the bell housing and with the auto trans it has to bolt to the motor, so that's why i got it...my son should be here Monday morning and we will start the auto trans project....i painted before i put the new seals in so i hope everything stays dry.....
01-19-2013, 10:54 PM | #5807 | |
01-19-2013, 11:35 PM | #5808 |
01-20-2013, 05:48 AM | #5809 |
Rear Baer calipers are on
1970 Chevy swb, project UGHH! 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ |
01-20-2013, 01:19 PM | #5810 |
Ordered and received the power plant that will be going into my latest build....
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=541803 Dennis H 1969 Chevy C10, SWB, LS3,6.2L engine 1969 Chevy Chevelle SS,BBC, Convertible |
01-20-2013, 06:37 PM | #5811 |
Finally got my rallies referbed..
Before and After.
1972 C10 CST LWB |
01-20-2013, 06:42 PM | #5812 |
Looks Great!!!!!
Is that paint or powder coat? How much? Posted via Mobile Device
1971 Chevrolet C10 Inflation Fighter 1994 C3500 Crew Cab Dually 454
01-20-2013, 06:48 PM | #5813 |
Rustoleum High Performance Wheel Paint (5 bucks a can), 4 coats over 3 coats of primer. Just sanded down good and cleaned them with por15 marine clean.
1972 C10 CST LWB |
01-20-2013, 06:49 PM | #5814 | |
of course some people just cut the crossmember out. thats not fun either
01-20-2013, 07:14 PM | #5815 |
after bed time last night i figured out what you were telling me...lol, you know how us old folks are, yes i am just about down to that now, got every thing unbolted , may just leave that for monday when my son comes to help me...i have a real good air chisel and grinder....
01-20-2013, 07:35 PM | #5816 |
I put an HEI in my 71 Cheyenne today, what a difference!
01-20-2013, 08:10 PM | #5817 | |
Sold the 63 and have a 68 now. 63 SWB C10 LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
01-20-2013, 08:21 PM | #5818 |
I may be doing this soon. What type of difference did you notice? Did you pull old one out and Stab new one in with rotor pointing same way to match old one? Thanks
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
01-20-2013, 09:34 PM | #5819 |
Old member
Replaced the old oil pressure senor. This one keeps the motor running as long as there is 5lbs of oil pressure to it.
It was leaking so I took it out. Have no idea why it was leaking though. Here is the new one.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-20-2013, 09:50 PM | #5820 |
Installed a vacuum gauge and painted door strikers
01-20-2013, 10:25 PM | #5821 | |
I checked the timing location with a light first, I couldn't find the timing specs on the truck anywhere, so figured it'd be close enough. Yes, all i did was pull the cap off the old distributer, took note where the rotor was pointing, and dropped the new one in at the same location. Once it was running, I just set the timing light up again and used the same number the old one was set at, +7 at idle. |
01-21-2013, 12:13 AM | #5822 | |
01-21-2013, 01:01 AM | #5823 |
Cursed the Gol Danged 49ers (GO RAVENS!!!!) and removed my inner fenders and heater to make room for Vitage Air.
01-21-2013, 10:50 AM | #5824 |
My 60's tranny cross member is bolted ~ I guess the DPO changed it , I'm glad he had the hard job instead of me ! .
HEI , or at the very least a Pertronix Ignitor breaker points is the smart thing for ALL older engines , you simply cannot imagine the improvement until you try it . I hope Myyamr7 remembered to open the spark plugs up to at least .045" . Even breaker point ignitions need .035" . Oops ~ 'puter says re boot time .
01-21-2013, 12:45 PM | #5825 |
Sanded and primed front bumper. Going to paint it after primer dries.
