Old 02-14-2013, 02:18 PM   #151
Red Foreman
Red Foreman's Avatar
Re: 1949 Chevy 3600 into a daily driver
I just stumbled across your build, that is a real nice truck, reminds me a little of my 56 jimmy, keep up the good work! Btw nice photography.
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 02-14-2013, 02:48 PM   #152
Coach529
Coach529's Avatar
Thanks!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 02-14-2013, 02:56 PM   #153
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'm sure enjoying your build. I like the "working man" types of builds with budget constraints and all that goes along with being a normal guy trying to fix up an old truck.
Tx Firefighter is offline   Reply With Quote
Old 02-14-2013, 02:58 PM   #154
Coach529
Coach529's Avatar
Thanks.......it sure is fun.
1949 Chevy 3600
Old 02-15-2013, 12:51 PM   #155
Coach529
Coach529's Avatar
Photoshopping for some wheel color options!!
1949 Chevy 3600
Old 02-15-2013, 02:45 PM   #156
NEWFISHER
NEWFISHER's Avatar
As much as red wheels have been as overplayed as matte black, I do like them on your truck. It gives it a proud American theme. As mentioned earlier, a tan color to tie into the pinstripe would be my 2nd choice and using a red pinstripe inside the beauty ring, or if red wheels then using a tan pinstripe on them just inside the beauty ring.
NEWFISHER is offline   Reply With Quote
Old 02-15-2013, 06:54 PM   #157
Dan in Pasadena
Dan in Pasadena's Avatar
Agree!
Dan in Pasadena is offline   Reply With Quote
Old 02-16-2013, 04:26 PM   #158
Coach529
Coach529's Avatar
I am not sold on the red at all........Satin Black with a bone or tan pinstripe is what I leaning towards. Maybe running newer, smaller caps so more of the rim shows.
To many choices!!
1949 Chevy 3600
Old 02-16-2013, 09:36 PM   #159
Dan in Pasadena
Like its YOUR truck or something!
Old 02-17-2013, 05:51 PM   #160
Coach529
Coach529's Avatar
Boss lady says no on red......and who am I to argue with her.
1949 Chevy 3600
Old 02-17-2013, 07:42 PM   #161
Coach529
Coach529's Avatar
New shift knob.
1949 Chevy 3600
Old 02-17-2013, 07:43 PM   #162
solidaxel
solidaxel's Avatar
...................A VERY VERY smart man !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-17-2013, 07:56 PM   #163
NEWFISHER
NEWFISHER's Avatar
New shift knob.
Weisco O.E. replacement for a 2 stroke Banshee? Or a 125cc?
Old 02-17-2013, 08:11 PM   #164
Coach529
Coach529's Avatar
It is a 200cc piston for either a Gas Gas or Kawasaki. Got it from a racing buddy. Might be a little too big. Might have to find a 125 piston.
I have been a moto guy pretty much my whole life.....
1949 Chevy 3600
Old 02-17-2013, 09:47 PM   #165
Dan in Pasadena
We do not argue with "She-Who-Must-Be-Obeyed". It's bad for the sex life. Hell, it's bad for ALL of life.
Old 02-17-2013, 09:48 PM   #166
Dan in Pasadena
You know they sell knockoff pistons as shift knobs on eBay, right? My dad had the same one on all his trucks when I was growing up.
Old 02-17-2013, 09:54 PM   #167
Coach529
Coach529's Avatar
Had no idea.........makes no difference anyway. I wanna make my own.
1949 Chevy 3600
Old 02-17-2013, 10:50 PM   #168
Dan in Pasadena
Yeah, they're phonies. Chrome, they have ring grooves but no rings. But they're the right size for your hand.
Old 02-18-2013, 01:52 AM   #169
NEWFISHER
NEWFISHER's Avatar
Me likey
Old 02-25-2013, 10:46 AM   #170
Coach529
Coach529's Avatar
Been busy in the wood shop....too busy and it is taking away from work on Henry.
Oh well......such is life I guess.
I did manage to complete my shift knob last night. It is a 200cc piston and it a bit big but feels really good.
Might try to find a 125 or 144 piston.
1949 Chevy 3600
Old 02-25-2013, 01:20 PM   #171
Dan in Pasadena
Looks good Coach. Did you take photos of HOW you did this? Was the wrist pin boss big enough as-is that you could just drill & tap it?
Old 02-25-2013, 01:25 PM   #172
Coach529
Coach529's Avatar
How am I supposed to make millions selling these things if I give away all my secrets. . Just kidding of course.
The wrist pin was way to hard to drill. I used a chunk of a 5/8" bolt cut shorter than the wrist pin. I drilled and taped the bolt 3/8-fine and then drilled and taped 2 holes #8-32 and installed screws so the piston would not rock back and forth.
I used a nut to lock the piston into place once I got it where i wanted on the shifter.
Easy.......took about 1/2 hour. I can take some pictures tonight.
1949 Chevy 3600
Old 02-28-2013, 09:46 PM   #173
Coach529
Coach529's Avatar
Got Henry on all fours and off the jack stands this week.
I love the stance.....but it may be too low.
I picked up some scabs rims and tires at the salvage yard. Way too wide rims, and too big of a tire. They rub pretty bad past 1/2 lock.
Took some measurements tonight off the wheel mounting surface.
5-3/8" from the wheel mounting surface to the tie rod ends
6-1/2" from the wheel mounting surface to the inside curl of the fender.
Hopefully my tires will not rub. Will be running 15" x 6", zero offset, 3-1/2" backspacing rims with 215/75-15 tires.
My shocks showed up too. The budget is tight........compromises had to be made. No Bilsteins. Midrange KYB's had to do!!
1949 Chevy 3600
Old 02-28-2013, 10:26 PM   #174
NEWFISHER
NEWFISHER's Avatar
The KYBs are great shocks. You might want to save the leafs you pulled and watch the current pack after you drive it a week. If the start to flatten, put the others back in. Stance looks great, how about a full shot?
Old 02-28-2013, 10:53 PM   #175
Coach529
Coach529's Avatar
The back isn't done yet......hopefully picking up a rear end this weekend.
1949 Chevy 3600
