Old 02-22-2013, 09:53 AM   #101
Clyde65
Clyde65's Avatar
Re: I hate some previous owner because.....
the PO of my truck did.....ummmm, well he.. oh crap! It was 24 years ago and I cant remember what he did or didnt do. this truck is about as 180 from when I got it than any ive ever owned before.
one thing you fellas need to cling to...over time, the disdain you have for these PO will subside...besides, would the knowledge of these things ( and some of yall knew at purchase) have changed your mind about the purchase? price?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-22-2013, 10:01 AM   #102
Bret B
Previous owner was my grandpa and he bought it new in 1965. He didn't do anything but drive it. Since I bought it, I have no one to blame but myself for half-adzed work. It was budget driven, high school kid, and little knowledge. Ahhhh, the fun I'm having now fixing my own short comings from then.
1965 Chevy short-step side, work in progress....
............................____
..................______l/___\____
.................|_/(0)\_ll____/(0)_l.
Bret B is offline   Reply With Quote
Old 02-22-2013, 11:13 AM   #103
da_bears_da1
Thank you to the person that started this thread. We do need a place to vent about POs. I am not going to go through all of the details, feel like I would fill up a couple of pages. Here is my list of head scratchers:
Instead of just using the front motor mounts on the 350 just bolted in he flipped them upside down and welded them in place. He also put a 283 intake on a 350 motor and for the inner bolts on the intake where they did not line up, he put on fender washers to hold them down. Rounding out the master cylinder holes to put in the wrong one.
He also said there was new metal in the floor boards. What was there was galvanized air duct metal held in with roofing paper and roofing shingles Cut off front door pillar and rear cab to put in an outer rocker and attached it with bondo.
Jeff
Simplify Life!
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=566533
da_bears_da1 is offline   Reply With Quote
Old 02-22-2013, 11:44 AM   #104
TBONE1964
Cluster King
TBONE1964's Avatar
I will join in here and say, I wish the PO would have used his head a little better and not drilled holes all over the place.
There is not one thing that I can think of that I cannot mount in the cab or under the hood of my truck that requires boring holes all over. All it takes is a little thought.
TBONE1964 is offline   Reply With Quote
Old 02-22-2013, 11:57 AM   #105
mr57
mr57's Avatar
I don't hate the previous owner. In fact I still am grateful after twenty three years of asking that he kept his word and when he did decide to sell, that I was first in line to buy it. I just wish he'd have decided to sell earlier. It was a lot better shape twenty three years ago...
mr57 is offline   Reply With Quote
Old 02-23-2013, 05:11 PM   #106
rifraz
rifraz's Avatar
I get frustrated when doing the metal work. I knew my truck needed rockers and cab corners. That's not a problem. I just hate finding spots that could have easily been fixed, but instead have filler that's 1/4 inch or thicker. Maybe they didn't know how to fix it. Or, maybe they just didn't care enough to actually fix it. Oh well, more work for me. Lol
rifraz is offline   Reply With Quote
Old 02-26-2013, 02:31 AM   #107
kingburnett
Previous Owner hacked out the engine rear cross member for dual exhaust.
[IMG][/IMG]
I like More's Law 'If more is better, then too much is just right.'
http://s1238.photobucket.com/albums/...20chevy%20k10/
1971 Chevelle - sbc 350 TH350
1961 K10 - sbc 400 4 spd M/T short stepside
kingburnett is offline   Reply With Quote
Old 02-26-2013, 03:19 AM   #108
jonathan-m
I appreciate the PO of my truck for keeping it road worthy for as long as he did. Once they get off the road for a long time most of them don't come back, and he put the effort into keeping her going as best he could. He did a lot of wonky things along the way, but then so have I.
Rockin' a '66 and loving every minute of it
jonathan-m is offline   Reply With Quote
Old 02-26-2013, 11:12 AM   #109
Tazfink
Tazfink's Avatar
When they "rebuilt" the engine they put the Pistons/Rods in the wrong cylinders... #1 Rod in #5 Cylinder.
"Rust does NOT look cool." - Me
"Patina is earned, not made." - Old Hot Rodder.
Cylinder Index
The Cylinder Index (or C.I.) is a measurement device in which the total number of internal combustion engine cylinders (working or non-working) owned by an individual (single-cylinder chainsaws, lawnmowers, 2-cycle, 4-cycle, multi-clinder diesels, trucks and farm tractors) are tallied. The Garage Logician who attains a C.I. in excess of his age is revered. - Joe Soucheray, Mayor of Garage Logic.
Tazfink is offline   Reply With Quote
Old 02-26-2013, 11:47 AM   #110
awbrown
I was rebuilding a carb last night in the garage when i spied the old Q jet off ol'blue.. It never ran right from the start and I didn't want to mess with it then so I swapped it to what I had on the shelf .. I though I might as well fix it since i was at it so I took it apart to find they used the wrong gasket for the cover to main body ..I can see how it happened because I picked up a kit for it and it was the same wrong gasket , one of the numbers on the side is not clear and when i substituted an 8 for the zero the right kit came up ...
awbrown is offline   Reply With Quote
Old 03-04-2013, 01:10 AM   #111
jesseo
jesseo's Avatar
[IMG][/IMG]
Ditto from my PO but they cut it off clean. I was a house framer in a past job and I think a plumber owned this truck before. Structure just gets in the way of plumbing.
jesseo is offline   Reply With Quote
Old 03-04-2013, 01:22 AM   #112
jesseo
jesseo's Avatar
Here are some pictures. of fun stuff from the. I have to admit. It just makes the repairing a bit more uhhmm fun. Decided I need a new cab. Too much work for the $$$ difference. The trans cross member is one of my favorite things along with the motor mounts. $5 a piece for new mounts and this is what is in there?
Bed and front clip look good. Frame is well fixable. I have to admit the little 283 sounds great and the rear end has made it all of the 5 miles I have driven it so far. Got it running after 2 months of hit and miss times to work on her. I dig the wheels and tires on this truck. That and the 283 short bed step-side were the deal closer's for me.
Old 05-13-2013, 10:42 PM   #113
FetchMeAPepsi
FetchMeAPepsi's Avatar
I hate that the PO used a dent puller and a slide hammer to pull out dents - in the fenders - and just hammered on them a couple of times, figured it was too much work, and mudded the crap out of the fenders, right over the dent puller studs.
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline   Reply With Quote
Old 05-14-2013, 02:59 PM   #114
gofastnut
gofastnut's Avatar
I wish the PO(my dad) and his PO (my grandpa) would have at least tried to do something about the body cancer: above the doors on the inside of the cab, the drip rail, and numerous other places that are pretty common.
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 05-14-2013, 07:15 PM   #115
MikeS.
MikeS.'s Avatar
Some PO hacked out the back of the cab and the front of the coach to make a crawl space between the 2 areas. Exposing the whole area to the outside.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 05-14-2013, 07:42 PM   #116
harleychop
My po had a "custom" choke cable. A lawn mower throttle cable with the rabbit and turtle plate still on it...nice.
harleychop is offline   Reply With Quote
Old 05-14-2013, 10:00 PM   #117
gofastnut
gofastnut's Avatar
Originally Posted by harleychop View Post
... A lawn mower throttle cable with the rabbit and turtle plate still on it...nice.
Jeff
C-10 Club
Old 01-19-2014, 03:56 PM   #118
dodgiesdad
dodgiesdad's Avatar
I just discovered I hate the previous owner because they "fixed" the rust in the frame I have been planning to use, with body filler!
dodgiesdad is offline   Reply With Quote
Old 01-19-2014, 05:05 PM   #119
TJ's Chevy
TJ's Chevy's Avatar
I hate the po before the po that drove the crap outta my truck...dented it up in the strangest places..and pulled parts that shouldn't have been pulled...and poorly maintained the engine. I do love that he left the gun racks on though...
Old 01-19-2014, 05:30 PM   #120
Rich 5150 69
Rich 5150 69's Avatar
PO at least they patched the floor with sheet metal and rivets, although looking from the bottom side it looked as if they had literally used an ax, the speaker holes in the doors are jagged bent panels, I just got two trashed doors for the panel replacement and a sheet of cold rolled 18 gauge sheet steel for the floor. When I go back to a crash box I`ll do the floor.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-19-2014, 05:39 PM   #121
Mikemelton
My complaint when the PO (my grandpa) got my '65 GMC from the original owner (my great grandpa) and swapped in a small block he didn't bypass the external voltage regulator which led me on a long goose chase over the last two years trying to figure out why my truck wasn't charging. I've had the truck since I was 12 which is almost 20 years now and I'm fixing some of the stuff that I did that I thought were good upgrades. Like an 86 frame swap. Just picked up a 1965 Chevy frame to swap under it.
Mikemelton is offline   Reply With Quote
Old 01-20-2014, 11:50 AM   #122
jbon64
jbon64's Avatar
although not a truck, my present project's PO must have owned stock in bondo. no complaints though , most all of it i could tell was there when i made the purchase .
hey.....smell my finger
64 nova wagon , 63 nova convertible
jbon64 is offline   Reply With Quote
Old 02-10-2014, 08:04 PM   #123
T.W.Dustin
T.W.Dustin's Avatar
Some PO on my '64 Short Step decided that epoxy was the best way to keep those pesky door handles and window cranks tight - jeez what a mess :-(
I'm trying to figure out how to get them off w/o bending or ruining anything
Please Watch for Motorcycles
T.W.Dustin is offline   Reply With Quote
Old 02-10-2014, 08:23 PM   #124
firemanjimtfd
firemanjimtfd's Avatar
Previous owner put side markers in side of bed . Worse part they say ford on the red lens also red back up lenses.
firemanjimtfd is offline   Reply With Quote
Old 02-10-2014, 08:42 PM   #125
Mathew21
Mathew21's Avatar
After reading through this thread I realize I need to ad the previous owner of my truck to my Xmas card list. He took pretty good care of my truck
Mathew21 is offline   Reply With Quote
