03-13-2012, 03:31 AM | #1 | |
But Found Her 25yrs Later!
I hate some previous owners because.....
I got the idea for this thread because of our new member's post:
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
03-13-2012, 03:33 AM | #2 |
Re: I hate some previous owner because.....
For me:
I hate some previous owner because..... They sold my buddy buckets.
03-13-2012, 03:36 AM | #3 |
because....
They hacked up the wiring to install some stupid toggle blinker. Just buy the right part. It'd been a lot less work. Oh, and they threw away the emergency flasher and installed this stupid toggle in the hole where it says 'Pull'
03-13-2012, 05:51 AM | #4 |
They cut a hole in the TOP of the dash for a speaker, and cut out most of the high hump tranny cover, which they siliconed a different one over the hole. And I think they used a ax to cut both. No problem I have since replaced both.
03-13-2012, 06:09 AM | #5 |
Check The Champ, Demonstrator
Kinda makes you wonder what the new owner of the truck you created and sold is going to say! LOL
03-13-2012, 07:03 AM | #6 |
they put body filler over duct tape and I found it... now I am scared
03-13-2012, 07:40 AM | #7 |
Duct tape is better than aluminum foil.........things people do to "hide" rust.
03-13-2012, 08:14 AM | #8 |
I could write a novel on my truck , begining with the brakes having the adjusters on the wrong sides so they actually would loosen instead of tighten... Or the floor shifter that had a 2 inch throw for all gears ...and the list would go on and on ....
03-13-2012, 08:40 AM | #9 |
It's Better With Nitro
...drilled more than 90 extra holes through the cab (firewall, floor pan, back panel, and dash), some larger than two inches in diameter, that I'm welding back up.
03-13-2012, 09:24 AM | #10 |
er... for extra ventalation?
http://s1299.photobucket.com/user/jb...23904108567829 |
03-13-2012, 09:35 AM | #11 |
For tossing out the ignition switch and just using the touch the wires together to get it to start method,then to run the electric fans,touch that wire to the ignition wires,nice,then wire would get hot. Love it
MY ADDICTION STAN THE MAN |
03-13-2012, 09:59 AM | #12 |
Not only did they cut my doors for speakers but used the same hot wrench on the inside of the door to open it up more with a 6x4 hole to get the window mechanism out, I have picked up to xtra junk doors for free to repair with...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
03-13-2012, 10:49 AM | #13 |
...just another truck junkie..
My '63 I actually have no complaints on but that's mainly because I'm only the 4th owner. My '71 was another story though.... Lot's of headscratching on that one.
Mike "Bear" Shea |
03-13-2012, 10:50 AM | #14 | |
What is it with guys who like to drill holes? My driver's door has 9 drilled holes in it for all of the rear view mirrors the previous owner had.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
03-13-2012, 11:43 AM | #15 |
They all wanted thru cab ventilation...
03-13-2012, 12:04 PM | #16 |
Was that the precursor to Astro Ventilation?
03-13-2012, 12:26 PM | #17 |
Just here to tinker
. . .they screwed a piece of plywood down over the space saver so I was "screwed" on the side of the road (old Corolla).
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
03-13-2012, 12:30 PM | #18 |
Ugh...the PO mounted everything to the firewall (front and back), had at least two different sets of seats (other than the original bench) and seat belts - apparently he had to drill a new set of holes in the floor for each set of new seat belts, a gun rack and he used sheetmetal screws to mount his speaker boxes behind the seat.
03-13-2012, 12:42 PM | #19 |
PO had apparently had a huge camper on my '62...drill all kinds of holes in the cab and roof. I like this big one, though.....
Put lots of dents in odd places, and the rust is unbelievable! I went to Wichita to get this truck, I can't believe how much more rust a truck up there has than an Oklahoma truck! PO also rigged some "helper" leaf springs on the back, not quite as nice as the factory ones. |
03-13-2012, 02:16 PM | #20 |
...for primering over what was probably a pretty nice patina of the original paint. Like others, I have the speaker hole cutouts in the doors to complain about and a crapload of toggle switches I've had to trace down. I think they were jerry rigged kill switches a.k.a. anti-theft.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
03-13-2012, 02:49 PM | #21 |
You`re one of the lucky ones, post CB antennae holes...10-4 good buddy another convoy....
03-13-2012, 05:41 PM | #22 |
Ah yes...I think i have welded shut like 20 drill holes in various places,SO FAR. I really loved the hackmaster clutch setup,somebody apparently didn't want to fix the hydraulic clutch on my 62,so they cut a hole in the floor and rigged up the z bar clutch linkage.
03-13-2012, 06:24 PM | #23 |
...they didn't keep the rear seats!
03-13-2012, 06:33 PM | #24 |
For throwing out the parking brake hardware from my 12 inch drum brakes.
Posted via Mobile Device |
03-13-2012, 06:47 PM | #25 |
Resident Photoshop Nerd
Hmm.. List:
- Rattle-Can-o-flage paintjob + fish sticker (you can still see some of it in the sig pic) It was originally a white truck; 2nd owner got it in the lime green with astroturf roof.. (base coat in the can-o-flage); then let his kids go wild with a set of rattle-cans.. and an apparent sticker of a large-mouth-bass. lol - 6 holes in either side of the body for what we assume would've been ladder racks - 6 holes per driver-door for various mirrors over the years.. only 1 was on the truck when we got it. - taking out stock seat to bolt wood and car-seats there instead. - astro-turf roof - still needs to be removed for new rattle-can paintjob. (lol, i know) It's not exactly a rust inhibitor either. <_< - puttng a 283 intake on a 400 block. We thought it was the original block, because we couldn't see the numbers on the block itself; so, until we started the rebuild, we had no clue. So yes, we have a 400sbc with a 283 intake. Hopefully we'll fix that.. time & budget allowing). - apparently driving by braille . There is a major dent/damage/attempted repair on every corner of this truck. Both front fenders, both rear fenders.. not to mention the hood. At least you can say, it survived.. we haven't really been down to the body-work so there's probably more 'fun' there. unfortunately i can't blame the p/o for the rusted floor panels <_< lol
PJ - 1966 C10 Panel -- Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn |
