driveshaft legnth?
Whos had to shorten theirs aftet lowering your c-10? Did you shorten both sections or just the front?
Posted via Mobile Device |
the boat guy
Re: driveshaft legnth?
What did you do to your truck?
Moving the transmission effects the front shaft. Moving the suspension effects the rear shaft. Coil trucks don't have as big of a problem as leaf trucks when it comes to the driveshaft changing length with suspension droop and compression. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
out of three that i lowered only one did i have a problem// i got away with just trimming 1/2-3/4 inch off the front yoke so it would not bottom out in the tranny
5" drop coils on.the back with the adjustable trac bar. PO lowered the front by heating the fronts ( to much) c downs. You just trimmed the yoke? Wouldnt the shaft need trimming?
#5 | |
the boat guy
Ill assume your shaft was correct before lowering, the rear shaft needs to be shortened. Posted via Mobile Device
