Old 03-28-2013, 07:22 PM   #1
Mark B
Mark B's Avatar
Where does the lower steering column seal fit?
Where does the lower column seal (in the bottom of the picture) fit in relation to the firewall pad, the firewall rubber seal, and the shaft mounting plate?
thanks
The Fixer
Mark B is offline   Reply With Quote
Old 03-28-2013, 07:32 PM   #2
JimKshortstep4x4
Re: Where does the lower steering column seal fit?
The seal that is on the column is the only one that you need. I believe that the seal you are asking about is for some of the larger trucks.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-28-2013, 08:08 PM   #3
Mark B
Mark B's Avatar
Thanks Jim. Maybe I bought it needlessly.
Does anyone else have an idea?
The hole in the seal I am asking about is about a 1/4 smaller in diameter than the steering shaft. But is is the same size as the brake booster rod hole in the firewall!
thanks
The Fixer
Old 03-29-2013, 07:29 AM   #4
There's only one location to seal,where the column exits the cab,so only the one seal.
