Old 04-03-2013, 02:42 PM   #1
rmvlt1100
rmvlt1100's Avatar
Fleetside Trim Clip Question ???
I'm starting to put my truck together. It's a 1965 Fleetside Short Bed. I was wondering where the best place to get the clips from? I have been to numerous web site for the clips. They range from plastic and metal combos that cost around $30.00-$50.00 to all steel ones that cost as much as $100.00. Anyone use the plastic ones and if so how did they work? If anyone has any info or recommendations let me know.
Thanks in advanced.
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 04-03-2013, 02:58 PM   #2
Clyde65
Clyde65's Avatar
Re: Fleetside Trim Clip Question ???
I would look at Classic Parts, they have always had good parts and great CS.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-03-2013, 05:40 PM   #3
newbe351
Mar-K sells just the clips. Theirs are plastic, but are sturdy.
http://www.mar-k.com/Catalog/itemDetails.aspx?LID=4376
Hit the "View Catalog" button.......
newbe351 is offline   Reply With Quote
Old 04-03-2013, 05:48 PM   #4
ChuckW
ChuckW's Avatar
Just installed new Mar-K trim on my 66 Fleet LWB. All of their clips worked great. Some were plastic and some had to be nutted on (Front fenders) But no problem with any..
The hardest problem was drilling the 100 holes in the fresh paint and new fenders.... But all's done now and looks great! (I think)
Good luck!
ChuckW is offline   Reply With Quote
Old 04-03-2013, 09:27 PM   #5
rmvlt1100
rmvlt1100's Avatar
Good luck!
Thanks for the info. I was looking at the Classic parts and Mark K and they both showed the plastic clips. I have had good luck buying parts from both companies. Thanks again and have a good night.
Old 04-03-2013, 10:35 PM   #6
198plus
198plus's Avatar
I used all metal clips with speed nuts, gives you a little more room to adjust the trim up or down to get everything lined up perfect.
198plus is offline   Reply With Quote
Old 04-04-2013, 12:23 AM   #7
rmvlt1100
rmvlt1100's Avatar
Thanks for the info. By chance do you know which one you used? It looks like there are about 100 or more style and sizes? Thanks again, Robert
Old 04-04-2013, 08:11 AM   #8
clemdaddy
clemdaddy's Avatar
i did this also... sometimes if the holes are not exactly the right size the plastic clips won't pull up tight and the metal spring clips can rebound and damage paint.
with the speed nutted clips... no problems. i got mar-k to send enough to do the job.
clemdaddy is offline   Reply With Quote
Old 04-04-2013, 08:53 AM   #9
rmvlt1100
rmvlt1100's Avatar
Thank you for the info. I have a few of the metal clips with the thread and nuts all ready some old and a few new ones. Around my house they only sell them by the piece, that can get expensive. I will give Mark- K a call today.
Thanks again, have a good day, Robert
Old 04-04-2013, 09:27 AM   #10
Realnoisy
Realnoisy's Avatar
I had the same question awhile back. Greg63 has a great idea...
I used spacers inside the back of the trim. I 3M'ed the spacer to the trim and then 3M'ed the trim to the truck. I used 1/4" plastic that I gathered from my work as spacers and they worked out well. I put the 3M about every 6" - 8" along the length of the trim.
As for location on the truck, I eyeballed it. I did the front fender first and then the door (so the recessed section at the front edge of the door piece would open without hitting the fender). After that the lower door piece and then the box. Once the lower door piece is attached and parallel to the upper door piece, the box upper and lower follow along from the door.
It's pretty easy once you get into it.
Greg.
A spirit with a vision is a dream with a mission - Neil Peart RUSH
Realnoisy is offline   Reply With Quote
Old 04-04-2013, 11:55 AM   #11
rideblue00
rideblue00's Avatar
Im interested in sticking my trim on also. Does anyone know what kind of trim tape is good and wont fall off? What did Greg63 use for tape?
rideblue00 is offline   Reply With Quote
