Old 04-10-2013, 03:53 PM   #1
BK'66Step
BK'66Step's Avatar
Will my rocker panels be strong enough?
So in the next couple days, I had planned on removing my cab to clean and paint the frame, but now I'm having reservations. My plan was to put the cab on a pair of movers dollys that I got from Harbor Freight, but I'm a little worried about doing that now with the condition of the rockers. I know it's a little hard to tell from the pictures, but do you guys think it would be safe to have the cab sitting on these rusty rocker panels or should I tackle that job first before I remove the cab? Thanks!!
BK'66Step is offline   Reply With Quote
Old 04-10-2013, 03:54 PM   #2
BK'66Step
BK'66Step's Avatar
Re: Will my rocker panels be strong enough?
Couple more pictures...
Old 04-10-2013, 04:24 PM   #3
jesseo
jesseo's Avatar
Doesn't look to bad to me. It looks like it should be ok. You can tack weld a couple braces across the cab (from door to door) to make sure it is ok but doesn't look bad enough to worry about to me.
jesseo is offline   Reply With Quote
Old 04-10-2013, 04:34 PM   #4
Lugnutz65
Lugnutz65's Avatar
In your 1st post, last picture - you have jack stands. Just use jack stands under the same places where the cab supports bolt on. Then you won't have to worry. The rockers look rusty, but would probably be OK if the weight is evenly placed along the whole length of each rocker, but I'd rather use the jack stands on the cab floor braces where the cab mounts go.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-10-2013, 05:28 PM   #5
BK'66Step
BK'66Step's Avatar
Hey that's a great idea!! I might have to go get a couple more jack stands because I was going to use those for the frame after I get all the suspension and rear end off but I will probably do that. Thanks!!
Old 04-11-2013, 09:40 AM   #6
kieth
kieth's Avatar
We used the same inexpensive furniture dollys, added a little wood to them to equalize the height and moved the cab around for months til we finished with it and were ready to paint it. Worked great. As others said use the cab mounting points not the sill. They are carrying the weight now and were designed to carry the weight. Kieth
kieth is offline   Reply With Quote
Old 04-11-2013, 09:48 AM   #7
da_bears_da1
We cut a 4x4 into 4 pieces, shorter in front and screwed them to dolly. We put the 4x4s under each cab mount location and then drilled holes thought the 4x4s and bolted through the cab mounting holes. Hope that makes sense.
Jeff
Simplify Life!
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=566533
da_bears_da1 is offline   Reply With Quote
Old 04-11-2013, 03:36 PM   #8
64tantruck
64tantruck's Avatar
I used the dollies from harbor freight with a few 2x4s and some 4x4 post. screwed together with 3 inch deck screws. Here's a pic.
glenn
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 04-11-2013, 04:16 PM   #9
BK'66Step
BK'66Step's Avatar
Nice! Thanks for the ideas and the picture! I know what I'll be building this afternoon!! :-)
Old 04-12-2013, 12:26 AM   #10
argonaut
argonaut's Avatar
That rust isn't that bad. It will be fine. you can support near the cab mounts or at the panel seam where the outer rocker meets the inner rocker.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
