Old 04-25-2013, 10:38 PM   #1
wayno
Air Bag Installation
So I'm installing my new porterbuilt drop kit and I've hit a question that I'm hoping one of you can assist with tonight - otherwise I will give nate and gang a call in the am. The kit comes with Ride Rite 9000 bags and it's pretty obvious how the top of the bag connects to the bridge using a couple of bolts - what isn't clear to me is how the bottom of the bag attaches to the lower bag mount - the bolt for the bottom of the bag isn't but maybe 3/4 of an inch long and as you can see from the picture the nut in the bottom of the bag is recessed about maybe 2 inches up into the center of the bottom of the bag - do I need to put some air into the bag to be able to bolt it up, will the bag just compress under weight or am I just plain missing something obvious - any insight would be greatly appreciated.
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 04-26-2013, 12:29 AM   #2
joedoh
joedoh's Avatar
Re: Air Bag Installation
just pull it out a little and bolt it up, it will be fine. I have those on the back of my truck, they ride like glass, so much smoother than a double convoluted bag.
Old 04-26-2013, 12:35 PM   #3
wayno
wasn't able to just pull it out by hand - I guess maybe I'll try pulling some air to it using the compressor?
Old 04-26-2013, 12:38 PM   #4
vegadesign
vegadesign's Avatar
its a sleeve bag so it just collapses around itself.
id put a couple of psi in it to just bolt it in.
the bags are a tad thicker in the area of rub for design purpose
find some air compressor fittings and a butterfly valve or even a schrader fitting and reducer
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 04-26-2013, 01:11 PM   #5
wayno
Thanks guys - first bag job so I'm a little out of my element - last night's education was on pinion angle at ride height etc - learning a ton along the way. Thanks again - I'll give that a go.
