Old 07-29-2013, 08:45 PM   #1
missionstreettattoo
missionstreettattoo's Avatar
dead burb 1972 gmc
I have replaced the starter, the positive terminal, the key tumbler , the ignition bracket the tumbler goes into, it still has no result when i turn the key. any ideas?
missionstreettattoo is offline   Reply With Quote
Old 07-29-2013, 09:29 PM   #2
rocknss
rocknss's Avatar
Re: dead burb 1972 gmc
Make sure your battery is good and you have a good ground.
rocknss is offline   Reply With Quote
Old 07-30-2013, 08:13 AM   #3
missionstreettattoo
battery is good and the connections are strong. and even hooking jumper cables up, still gets no result when i turn the key. the lights and stereo will come on, but no other sound from the key switch. just dead.
Old 07-30-2013, 08:54 AM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Is it an auto trans with nuetral safety switch? Need to get a test light and start tracing where you have power and where you don't.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-30-2013, 09:53 AM   #5
Hart_Rod
Hart_Rod's Avatar
Originally Posted by ol blue k20 View Post
is it an auto trans with nuetral safety switch? Need to get a test light and start tracing where you have power and where you don't.
posted via mobile device
+1
Hart_Rod is offline   Reply With Quote
Old 07-30-2013, 10:26 AM   #6
missionstreettattoo
when i bought it and looked under the dash , it had one of those crazy damn security systems with wires going everywhere! it is all tapped into the back of the ignition and i am thinking that is where the problem is.
Old 07-30-2013, 10:56 AM   #7
Warrens69GMC
Warrens69GMC's Avatar
Fusible link? Do you have the second power lead to the fuse box hooked up? It bolts to the inner fender on an isolator, which feeds the fuse block.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 07-31-2013, 07:53 AM   #8
missionstreettattoo
found the issue! when i replaced the starter and the positive battery terminal going to the starter, i only reattached the thin starter wire going back to the ignition. it had worn through in several spots. replaced that and voila, shes running again!
Old 07-31-2013, 01:03 PM   #9
Ol Blue K20
Congrats! Glad ya found it.
Dale
Old 07-31-2013, 08:56 PM   #10
rocknss
rocknss's Avatar
Glad you found what was the issue!!
Old 08-02-2013, 10:13 PM   #11
70cst
70cst's Avatar
In one word: VICTORY
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
