Old 08-01-2013, 09:26 PM   #1
mxsurfer184
3in spindle question...
My truck has a flip kit in the rear and 3in spindles with 1/4 coil cut on stock springs up front. To get the front lower should I go with 1 or 2 in springs? Will I need any additional mods? Would 2in spindles and 2 in springs look better?
Thanks for the advice.. Just looking to get the front end a little lower
mxsurfer184 is offline   Reply With Quote
Old 08-01-2013, 10:26 PM   #2
bdiamond
Re: 3in spindle question...
I cut a whole coil off a pair of Moog 6102 coils. The truck sat exactly the same as the 3" coils that were in it before. 1/4 coil probably didn't drop it more than the thickness of the coil.
bdiamond is offline   Reply With Quote
Old 08-01-2013, 10:37 PM   #3
cochino12
It followed me home?
cochino12's Avatar
I'd just cut more of the coil you have, they ride just fine like that. Nice truck
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-01-2013, 10:46 PM   #4
mgchevyparts
mgchevyparts's Avatar
1/4 coil is almost nothing, I would do 1 full coil but you can experiment and do 3/4 coil first.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 08-02-2013, 08:29 AM   #5
mxsurfer184
sounds like cutting more coil is the way to go...
second question, I'm running stock tires up front that sit pretty high. will I have rubbing issues once I go that low?
Old 08-02-2013, 02:41 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'm running a flip kit in the rear and 3 inch spindles with one coil cut on my truck. It sits right.
You're definitely going to need shorter front tires. I went about 2 inches shorter front tire than the rear ones. Stock 28 inch tall tires are gonna run a lot with any real front drop.
Tx Firefighter is offline   Reply With Quote
Old 08-02-2013, 02:56 PM   #7
mxsurfer184
Tx, can you post a photo of your stance?..
my fronts are 235/75-15
my rears are 255/60-15
should I moved the 255's up front and get the 295's for the rear..?
Old 08-02-2013, 03:08 PM   #8
Tx Firefighter
I don't have any real pictures of it right now. When I do a build thread, I'll take some proper pics. It's kind of a patina wagon right now with all the surface rust and mismatched panels. It's an old longbed I got for free and shortened the frame for a Craigslist cheapie bed.
Her is a cell picture snapped through my windshield.
Old 08-02-2013, 03:08 PM   #9
Tx Firefighter
Forgot to add, tires are 215/75-15 front and 235/75-15 rear.
Old 08-02-2013, 11:06 PM   #10
mxsurfer184
should I moved the 255's up front and get the 15x10 295's for the rear..?
