Old 08-13-2013, 07:05 PM   #1
wraprail
wraprail's Avatar
Ride Height Sensor Linkage
Decided to upgrade the rubber jointed linkage on my ride height sensors for Dakota Digital air ride system. These look to be the exact same height sensors that RideTech uses on their system.
This is what comes with the sensors.
The rubber connectors are not very flexable and just don't look very hi tech. They supply worm drive hose clamps that you clamp around the rubber to keep the steel round bar from slipping. These I never installed. Way to cheezy for a "high dollar" system.
This is what I came up with.
Here are the parts.
8 female 1/4" standard rod ends
8 1/4"-20 x 1 1/2" allen bolt + nuts
8 1/4" x 1/4" spacers
3 foot 1/4" aluminum un-threaded rod
Pretty simple. Cut the rod to length, cut 1/4"-28 RH threads into each end
and thread on the heim joints. No jam nuts needed.
I was a little concerned about the weight so I weighed them.
As you can see the bulky rubber ones weighed 3.4oz. and new ones weighed 3.2oz. And I used standard steel rod ends. Aluminum heims would save even more.
Total cost was less than $8 per wheel or a total of $32
I think it looks alot cooler and any binding it may have is totally cured. I think this could help to extend the life of the sensors. Can't hurt.
wraprail is offline   Reply With Quote
Old 08-13-2013, 08:13 PM   #2
Pro Performance
Pro Performance's Avatar
Re: Ride Height Sensor Linkage
Nice upgrade and thanks for sharing!
Pro Performance is offline   Reply With Quote
Old 08-13-2013, 09:07 PM   #3
k_n_browning
I think that I would have left one end rudder.Just so it has a little give to it.That way if the suspension over compress or extended it might save the sensor.but that's me.
k_n_browning is offline   Reply With Quote
