cab weight?
does anyone know how much a cab for a 72 c-10 weighs ? I'm fixin' to lift my cab so I can shorten frame, and want to know if my shop'x rafters will hold it. doors will be off.
A bare cab is less than 200 lbs. All the interior parts add up real quick, probably 400 lbs without doors. Most of the weight is in the firewall, so make sure you consider that before you start lifting. Run a good 10' 4x4 across 4 of the rafters to spread the load and you should be fine.
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" Last edited by ljbear; 12-04-2003 at 12:24 PM. |
Robert Olson Transport
![]() Join Date: Oct 2002
foud guys can lift a cab up easy enough ive done it with both 76, 81 and 72 cabs
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
I got it off, alone and no lift - did it by myself boy it's heavy! getting it back on is my next problem ( after I finish the frame)
72 c-10 81 c-30 67 c-10 just sittin in the woods) 70 C-10 " " " " to compleete frames 67, 70 - in woods 2002 toyota tundra. 12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker |
its all about the +6 inches
Frank...how the h#ll did you do that?
I know the cabs are not realy heavu..but they sure aren't light either. |
jacked it off frame, slid two pieces of channel iron under cab - then worked it off. and I have a bad heartalso had cancer removed lasdt year, - today I rest
