Old 09-01-2013, 10:32 PM   #1
TheOcho
TheOcho's Avatar
This is why you don't run "P" tires on a pick-up...
I believe the belts broke while hauling a load of top soil last week. The next day, I was running empty and noticed a low speed vibration. When I parked it, I saw some tread separation. I left it parked in my father's driveway and today when I stopped by I noticed this. My father said he heard (what he thought was) a gunshot about twenty minutes before I got there.
TheOcho is offline   Reply With Quote
Old 09-01-2013, 10:40 PM   #2
lilpoindexter
lilpoindexter's Avatar
Re: This is why you don't run "P" tires on a pick-up...
How old are those things?
lilpoindexter is offline   Reply With Quote
Old 09-01-2013, 10:41 PM   #3
TheOcho
TheOcho's Avatar
I'm not sure, they were on the truck when I bought it.
Old 09-01-2013, 10:57 PM   #4
mgchevyparts
mgchevyparts's Avatar
Exactly what I was going to ask. I bet they're old, more then 6 years or so. The date is coded on the sidewall
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 09-01-2013, 11:45 PM   #5
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I agree, look's like age is ass much to blame as the over load.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 09-01-2013, 11:47 PM   #6
TheOcho
TheOcho's Avatar
I've had the truck for two years, the original owner passed away about 5 years before I bought it. So they're at least seven years old.
Old 09-02-2013, 12:29 AM   #7
TwoFiftyShifter
Can the thread title be changed?
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 09-02-2013, 12:59 AM   #8
meatwagon83
meatwagon83's Avatar
those tires are ancient!!!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 09-02-2013, 01:21 AM   #9
TheOcho
TheOcho's Avatar
I'm sure they're old, but I've seen older, dry rotted, tires haul heavier loads over longer distances. I'll agree age is certainly a factor here but this just wasn't enough tire for the job. And it wasn't one load either. I hauled a lot of crap on those tires, as I'm sure the previous owner did also. They'll be replaced with LTs. I never liked P tires on a truck anyway.
Old 09-02-2013, 01:25 AM   #10
mud.man.rj
mud.man.rj's Avatar
Looks wicked, at least it happened when parked not driving.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 09-02-2013, 01:42 AM   #11
TheOcho
TheOcho's Avatar
Thank God for that...
Old 09-02-2013, 09:59 AM   #12
KQQL IT
At the body shop.
KQQL IT's Avatar
I have had LT's separate carrying no load. from age.
Be happy it didn't tear the fender or worse. And replace you old tires.
KQQL IT is online now   Reply With Quote
Old 09-03-2013, 04:51 PM   #13
Domer
Domer's Avatar
my factory spare seperated. it was on the front right going home, crusing down the grapevine (in cali north of LA) pulling a 24ft enclosed with my 77 blown c10 in it... that sum ***** put dents in my truck and there is rubber marks all the way down the truck.. age can abuse tires pretty badly...
Domer is offline   Reply With Quote
Old 09-03-2013, 05:20 PM   #14
Edahall
Never have had any issues running P-metric tires other than they don't handle as well. That said, I bought a set of wheels and tires for my 3/4 ton 4x4 Suburban and the tires on it are P-metric. The tire shop told me they would be worn out in no time. I've driven a year so far with these tires and hardly notice any wear whatsoever.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 09-03-2013, 11:40 PM   #15
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Holy sheet wow that's crazy! Good thing you weren't driving it when it happened. Could have been so worse.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 09-04-2013, 07:02 AM   #16
BigBlocksRule
What do you call a guy that uses very old tires?
Hitchhiker
What do you call a guy that uses very old condoms?
Baby Daddy!
Age doesn't do either of 'em any good...
BigBlocksRule is offline   Reply With Quote
Old 09-04-2013, 07:18 AM   #17
Driving a truck using a tire rated slightly higher than you may need is certainly smarter than running ones with marginal or slightly under rated tires. If it's just a car with a bed you don't have to worry.
They say 7 years is about where you draw the line for age...with the newer tires that seem to be intentionally made to only last so long,putting tire company profits before customer safety. I know of many 20 or more year old tires that still serve their purpose and have no dry rot. The tires on my '72 are the ones that came on a truck I bought in '04 and have no idea how long they were on that truck-1st picture. The second picture is from '07 when I had tires on it I bought in '91. The '71 wrecker I just sold had tires on it I bought in '88. When I git rid of my '71 Custom Camper/slide-in camper it had tires I had bought in '89 on it. These are all truck tires from before they were made to rot before wear (unless driven daily)
Old 09-04-2013, 09:22 AM   #18
Skunksmash
Skunksmash's Avatar
That's what happened to mine when I very first got my truck.. maybe they were P tires too? Can't remember, didn't really look. Just replaced 'em.
Skunksmash is offline   Reply With Quote
Old 09-04-2013, 09:23 PM   #19
hatzie
Moderator
hatzie's Avatar
I've had old 10 ply tires do that. I would guess that age is a much larger factor than exceeding the load range... The combo of age and overloading is the kiss of death.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
