Old 09-12-2013, 12:46 PM   #26
tinydb84
tinydb84's Avatar
Re: 66 Synergy Green
If that was a fleetside I would sell my kidneys to buy it.
David
Instagram: myfabguy
Old 09-12-2013, 01:34 PM   #27
markeb01
Senior Enthusiast
markeb01's Avatar
Outstanding! What a transition, that body work, paint, and color are beautiful. That bed floor is spectacular!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-12-2013, 03:11 PM   #28
doobiebro
doobiebro's Avatar
Looks good Carnal! What A/C system did you go with? Is it aftermarket?
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 09-12-2013, 03:32 PM   #29
mlevario99
Thanks for all your comments. The wood bed needs more work, I took the measurements for the width of the boards from the internet, but they are off, so I might have to redo the boards.
The AC is from vintage air, I have not installed it yet, I am still working in the wiring inside the cab, and now that it is raining I found out water is coming into the cab thru the wipers motor, I did not install a new gasket, so I need to install that now.
The body work took a little longer that expected, but it was worth it. They did a really good job.
mlevario99 is offline   Reply With Quote
Old 09-22-2013, 11:15 PM   #30
Slammed gmc
Slammed gmc's Avatar
Looking good, where did you get the engine cover?
Slammed gmc is offline   Reply With Quote
Old 09-22-2013, 11:18 PM   #31
mlevario99
Thanks, I bought it at one of the Chevy dealers, do not remember the part number but I might have it some where
Old 11-03-2013, 11:19 AM   #32
mlevario99
I am still working in the wiring is taking me a while because not enough time to work on it. I am almost done tho. I run into a little problem. Here is the little problem, if I plug the steering column wiring plug into the wiring harness plug, the running lights come on, the key is in the off position, now, if I turn the signal either to the left of right, the fuel pump comes on. I check the wiring plug from the harness, and I get power in the black wire which is the ground horn, I also get power in the purple wire and the brown wire which are coming from the flashers. Has anyone had something similar happen to them. Now, if the turning level is in the off position, I can start the truck without a problem, and once the truck is running, I turn the turning signal to either left or right and nothing, for some reason, is sending power to the computer.
Old 11-03-2013, 12:08 PM   #33
TJ's Chevy
TJ's Chevy's Avatar
Cool truck! Paint came out smooth!
