09-13-2013, 04:23 PM | #1 |
gauge cluster cleaning?
So the other day I pulled apart my gauge cluster to clean/fix bulbs and gauges that werent working.
How do you clean the gauges themselves without smearing the painted letters/numbers? I tried using a dry paper towel but it started smearing just a tiny bit. Thanks.
Austin 1996 Chevrolet K1500 Silverado 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
09-13-2013, 05:53 PM | #2 |
Getting Old; Going Broke
Re: gauge cluster cleaning?
Compressed air and a clean and dry detail brush/paint brush.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
09-13-2013, 11:26 PM | #3 |
While u have it out I would suggest, in my humble opinion, to get some chrome rattle can and take your gauges out then spray the back drop. It will make it a lot brighter for way cheeped.
Faith and Patience with my truck, that is what i pray for every day! See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013 |
09-15-2013, 10:10 AM | #4 | |
78K & 79C Jimmys
and paint the front too the metal rusts I used air and Qtips for dusting,dry paper towels carefully tho as too hard will leave swirls on the face I used green dash bulbs in it
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 09-15-2013 at 10:16 AM. |
09-15-2013, 10:17 AM | #5 |
I'll bet you a toonie there was in fact a sawzall also involved.
09-15-2013, 10:19 AM | #6 |
78K & 79C Jimmys
and i added a second colour red to the 78
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
09-15-2013, 10:32 AM | #7 |
Silver paint and LED 194 bulbs. I got mine from superbrightleds.com. And obviously a sawzall.
Few things in life will make you look stupider than putting a dollar sign after a number. |
09-15-2013, 10:37 AM | #8 |
The clear part can be shined up with a headlight buffing kit.
09-15-2013, 10:39 AM | #9 |
78K & 79C Jimmys
not till i put the radio in lol
09-23-2013, 12:05 PM | #10 |
Thanks for the responses yall.
Did you ever have any problems with the circuit board on the back? Mine is falling apart.
09-23-2013, 12:47 PM | #11 |
Don't use chrome or silver paint, it will make the lighting worse. paint the cluster case gloss white, it'll increase the lighting dramatically.
I tried the chrome paint first, it turned out terrible, could barely see the gauges at night. I pulled the whole cluster apart again to replace the printed circuit, and I re-did the inside of the case with gloss white. Far better, with just the stock bulbs it was much brighter. |
09-23-2013, 01:37 PM | #12 | |
http://coloradok5.com/forums/showthread.php?t=296187
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
09-23-2013, 03:49 PM | #13 | |
78K & 79C Jimmys
09-23-2013, 11:51 PM | #14 |
Motornut can you please give details on how you painted the gauge needles?
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
09-24-2013, 06:33 AM | #15 |
78K & 79C Jimmys
I had them out of the cluster
cut squares of printer paper and a thin slit to the middle slide under the needle, pulling the pin into the slit turn paper as needed Posted via Mobile Device
09-24-2013, 11:58 AM | #16 |
Thank you Motornut I was wondering if something like that might work.
