Old 09-13-2013, 04:23 PM   #1
TheBlueBomber
TheBlueBomber's Avatar
gauge cluster cleaning?
So the other day I pulled apart my gauge cluster to clean/fix bulbs and gauges that werent working.
How do you clean the gauges themselves without smearing the painted letters/numbers? I tried using a dry paper towel but it started smearing just a tiny bit. Thanks.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 09-13-2013, 05:53 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: gauge cluster cleaning?
Compressed air and a clean and dry detail brush/paint brush.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 09-13-2013, 11:26 PM   #3
nheller76
nheller76's Avatar
While u have it out I would suggest, in my humble opinion, to get some chrome rattle can and take your gauges out then spray the back drop. It will make it a lot brighter for way cheeped.
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 09-15-2013, 10:10 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
this is the best idea for them since they have a blue hue to them
and paint the front too the metal rusts
I used air and Qtips for dusting,dry paper towels
carefully tho as too hard will leave swirls on the face
I used green dash bulbs in it
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 09-15-2013, 10:17 AM   #5
RandyP
RandyP's Avatar
I'll bet you a toonie there was in fact a sawzall also involved.
Old 09-15-2013, 10:19 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
and i added a second colour red to the 78
John
Old 09-15-2013, 10:32 AM   #7
BONUSCAB
Silver paint and LED 194 bulbs. I got mine from superbrightleds.com. And obviously a sawzall.
Few things in life will make you look stupider than putting a dollar sign after a number.
BONUSCAB is offline   Reply With Quote
Old 09-15-2013, 10:37 AM   #8
BONUSCAB
The clear part can be shined up with a headlight buffing kit.
Old 09-15-2013, 10:39 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
not till i put the radio in lol
John
Old 09-23-2013, 12:05 PM   #10
TheBlueBomber
Thanks for the responses yall.
Did you ever have any problems with the circuit board on the back? Mine is falling apart.
Austin
Old 09-23-2013, 12:47 PM   #11
MalibuSSwagon
Don't use chrome or silver paint, it will make the lighting worse. paint the cluster case gloss white, it'll increase the lighting dramatically.
I tried the chrome paint first, it turned out terrible, could barely see the gauges at night. I pulled the whole cluster apart again to replace the printed circuit, and I re-did the inside of the case with gloss white. Far better, with just the stock bulbs it was much brighter.
MalibuSSwagon is offline   Reply With Quote
Old 09-23-2013, 01:37 PM   #12
Ski-me
Ski-me's Avatar
I got the opposite results using Chrome Paint. I did the cluster and back side of gauge cover......
http://coloradok5.com/forums/showthread.php?t=296187
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 09-23-2013, 03:49 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
some paths lifted but flatted them out and used crazy glue to hold them back down
John
Old 09-23-2013, 11:51 PM   #14
ron350
ron350's Avatar
Motornut can you please give details on how you painted the gauge needles?
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 09-24-2013, 06:33 AM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
I had them out of the cluster
cut squares of printer paper
and a thin slit to the middle
slide under the needle, pulling the pin into the slit
turn paper as needed
John
Old 09-24-2013, 11:58 AM   #16
ron350
ron350's Avatar
Thank you Motornut I was wondering if something like that might work.
