Old 10-12-2013, 09:36 PM   #1
crewcabshorty
crewcabshorty's Avatar
king pins
one of my winter projects this winter is to change the king pins on my 87 1 ton dana 60. I have never done one. do they unscrew? pressed in ?
crewcabshorty is offline   Reply With Quote
Old 10-12-2013, 11:34 PM   #2
andrewmp6
Re: king pins
Here you go http://www.pirate4x4.com/tech/billavista/PR-Kingpin/
Old 10-13-2013, 11:18 AM   #3
1968vetL-71
Junior Member
1968vetL-71's Avatar
Re: king pins
Crewcabshorty- I just did this a couple weeks ago replacing EVERYTHING on my dana 60 for my 91' crew cab. I basically started with a housing and bought every bearing, seal, bushing including new srw hub and rotors for mine. Changing the kingpins was not as hard as most posts you will read about. I bought a 7/8" Allen wrench from Grainger item #4RE72 for 27.00. I applied a little heat around the base of the kingpin and with the help of a 8' cheater pipe (1/4" DOM 2" tubing) slipped over the Allen wrench.... Pop! They came right out. You will be surprised how well they are in there. It took everything I had on the end of the cheater stick, lol. Installing them, clean the surface well, apply some red loctite and reverse the big cheater stick method. I've done this before and had years of daily driving with no problems. Just don't be afraid to lean on it when tightening them. Remember they were almost 600'lbs of torque from factory. Hope this helps.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 10-13-2013, 11:35 AM   #4
79Betty
79Betty's Avatar
Re: king pins
600 ftlbs !?! I'm gonna need a bigger torque wrench...
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 10-13-2013, 02:45 PM   #5
83GMCK2500
Re: king pins
Naaaah, 200# guy with a 3' stick = 600lb-ft of torque.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 10-13-2013, 03:35 PM   #6
1968vetL-71
Junior Member
Re: king pins
I was honestly worried about the Allen wrench giving way but surprisingly it's made the in good ol USA and it never bent or anything. If you hear anything as your tightening them down its prob not ur homemade torque wrench but rather a hernia or hemroid bursting.
