#176 |
![]() Join Date: Jul 2010
Re: 63-87 rack and pinion
Hmmm, New close ratio box, $429. new inner and outer tie rod ends, $138.44. new idler arm, $47.35. thats $614.79 for the stocky way. So, for the low low price difference of only $234.21 (insert loud aussie voice here) you, yes you can have a better driving, quicker driving truck. Operators are standing buy NOW
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#177 | |
Truck and auto performance nut
whoa......price on this page says $849
.......yet when you click to purchase you go to this page and its $949? http://www.nolimitparts.com/prodinfo...ber=3GC-FT-500 Which is it? Heck these days $100 won't buy much but when you put a bunch of them together (as in 8 and a half) it will. ![]() How about a package deal Rob? We buy the R&P kit, Rear shock relo kit, and the Adj. long panhard rod kit so we get the ride benefits of the full No Limit effort.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#178 |
Yea I wish I would have bought when he had his "pre-production" sale.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#179 |
forum members get a 10% discount, we round it off at 849. Merry Christmas all year
#180 |
Is there a code we enter for the 10% or do orders need to be placed over the phone to get the discount?
#181 |
![]() Join Date: Jul 2013
Rob, you are right. It is in my plan, just have lots of needs.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#182 |
Best to call for now, our new web site is still being worked on, it will have a spot for forum discounts soon.
#183 |
Just read through the entire thread in one go.. I am inspired, but I live on the other side of the atlantic, would you be able to get me a shipping price for the $849 set to the Netherlands? My 69 C10 is stock with the small adjustment of a complete frontmember swap with a 73 so I could have diskbrakers i.s.o. drums..
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
#184 |
Street Rod Restoration
![]() Join Date: Jan 2004
Hey Rob, have you had anyone who Z'd the frame on their 70s c10 and had issues setting up the steering? I have one in the shop now that has a 3.5" z'd frame
Follow me on Instagram @ hot_rod_shop |
#185 |
I think it would be OK. the steering UJ angle would be less, thats good. Maybe rack /tie-rod clearance under the rail, depending on how it was 'Z'd'.
#186 |
![]() Join Date: May 2014
Wondering if I can still run 15" steelie wheels with this setup.? Brother's site says 17" wheels minimum.
How about if I went with the No Limit wide ride.? Could I run my 15's then.? Last edited by kitsbeach; 06-05-2014 at 06:16 PM. Reason: more info |
#187 |
I have 15in chrome rally's and didn't have an issue.
#188 |
Is there a manual rack that will work in place of the power unit?
#189 |
Our WideRide has 12" brakes - So, "most" 15" wheels will fit. We have had a few that we had to grind a little off of the caliper and the weld inside the wheel.
15" wheels should not be a problem with the rack and OE crossmember. We do not make this for a manual rack.
#190 |
Where does one order a replacement rack for the 67-72 c10? Mine leaks a little bit
#191 |
The racks start out as late model chevy truck (like 2000-2006 1/2 ton 2WD) We cut off the OE passenger side mount, and rotate the passenger side housing 180*. To fit up with the rotated housing, the formed pressure hard lines are custom made to fit. All of the consumable parts, boots, seals.... are from the 2000+chev 1/2T - Now, if it leaking with normal use, we will warranty it N/C. Just call for an RA # and send it in. We'll chevk it out and service it and send it back to you.
#192 |
#193 |
ok @robnolimit you mentioned it would or should work fine with a Z'd frame what about a stock pancaked crossmember (2in)? instead of bolting the bracket on could i weld it in place after of course making sure i was centered etc? any info from all would be appreciated or and other suggestions
its a 1963 suburban 2in pancaked stock crossmember thx in advance
current project: 1964 chevy II Wagon 1956 3100 1972 c10 burb bagged 1962 GMC burb 1963 c10 burb 1966 c10 burb 1995 chevy lowerado 5/7 static drop daily driver 1963 c10 step side 1965 super sport impala 1967 c30 |
#194 | |
#195 |
ok no i have not raised the motor. i am in the build phase of the project so i can raise the the motor still if need be. I'm just hesitant on dropping that kind of scratch and not have it work for my application. i have also heard/read that the rack n pinion would interfere with motor mounts for the genIII motors do you have any knowledge of these rumors?
thx in advance again
#196 | |
#197 |
I'm just glad to be here!
I used the No Limit rack with a LM7 (genIII engine) in my son's 82. I built my own engine mounts to set it back and the bottom of the LSA oil pan about 1/4" higher than the bottom of the front crossmember. I did not do a section of the crossmember, but raised it in the frame 1.5". I had to use 3 u-joints in the steering shaft with a support bearing, but it all worked really well.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#198 |
alright I'm sold then rack n pinion it is
#199 |
robnolimit,
I have installed an 84 Chevy cross member in my 46 Chevy short school bus. I narrowed the cross member 5 1/8". To ensure I didn't screw around with the geometry of the suspension the only thing I modified was the cross member. Do you have a rack & mount that will work for the narrower cross member? THANKS |
#200 |
Hey Rob,
Is this R&P available for 73-87 C10s? |
