Old 11-17-2013, 10:47 AM   #1
chewychevy67
will powdercoat hold up on 327 spark plug shields
If I get my spark plug shields powdercoated on my 327 with ramhorns would it be too hot there or would the coating hold up? Anyone done this?
chewychevy67 is offline   Reply With Quote
Old 11-17-2013, 10:52 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: will powdercoat hold up on 327 spark plug shields
Powdercoat melts at 400. I woould think Jet Hot would be a better choice.
Tom Vogel is offline   Reply With Quote
Old 11-17-2013, 03:21 PM   #3
chewychevy67
Yeah I figured that but thought if they weren't touching the manifold they might be ok.
Old 11-17-2013, 03:50 PM   #4
71 super
71 super's Avatar
My heat tube on big block is powder coated and it has held up without issue, shield will get no more heat than it does, they should be fine with powder on them
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 11-17-2013, 07:51 PM   #5
Fitz
There are powdercoats that are good to 1200 degrees. See the Caswell Plating website. They have it.
Fitz is offline   Reply With Quote
Old 11-17-2013, 08:24 PM   #6
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Well... There you go. Learn something new every day.
Old 11-17-2013, 09:28 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It will be fine. I do a lot of motorcycle exhausts with ceramic and powdercoat the heat shields. It works well and lasts. Mine is probably a much "worse case" situation in that the heat shields screw directly to the headers, with only a thin insulated washer under each screw to isolate the exhaust heat from the shield.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-17-2013, 11:59 PM   #8
cool68
be sure post some pics of engine when done.
cool68 is offline   Reply With Quote
