I don't like seeing my rear wheels not centered or close to it in the rear fender opening. I lowered the rear 6" and moved the bed closer to the cab which added to the off centering of the rear axle in the opening.
Now the question, does someone make a shorter trailing arm for coil springs, not air bags? Thanks for the help. |
Who Me?
Re: Rear wheels not centered in fender opening
I would think you can take a section out of the trailing arms. Don't forget to take some from the driveshaft too.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
67-72 parts collector,…
![]() Join Date: Nov 2002
Or move the trailing arm crossmember forward.
That's unusual, These trucks naturally have the rear wheels off center toward the front. Something isn't right. What exactly has been done to your trucks suspension and/or frame?
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#5 | |
![]() Join Date: May 2007
I say dont section the trailing arms because they are two pieces of c channel joined in a way to allow them to twist torsionally when one wheel goes up over a bump.
are you trailing arms from the 78?. They may be longer than the 66. the w/base is longer in the 68. looking back at your build thread where it shows your frame and rear axle it does seem to be to far back. it is located at the back of the raised section of the frame section where the axle resides
I do not know whether or not that they are of the same length, but there has to be a reason ron |
I believe all trailing arms are the same length. The difference between a swb and a lwb is the placement of the crossmember
I used the stock 66 arms. The only thing I changed was the trailing arm cross member. I used one from Early Classic because is gave more ground clearance for lowered trucks. And yes I installed it correctly.
I just emailed Early Classic asking them about my problem with attached pictures. I will see what they have to say.
#11 | |
![]() Quote:
Sam |
#12 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I suggest he move his early classic crossmember forward. And then his shaft may also need to be shortened. But do not cut the trailing arms. Move the ece crossmember forward.
#13 | |
1961 crewcab
is the crossmember too far back, and are your springs leaning to the front a little bit? I agree with the couple of people that said it is safer to move that crossmember than shorten the stock trailing arms I guess the other question is how close to 115 is your wheelbase right now? just checked out your build, looks nice! another thought.. cpp ads that I have seen show aftermarket trailing arms.. I wonder if those could be ordered , or retro fitted for what you need.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 11-18-2013 at 01:55 AM. |
#14 | |
![]() Quote:
Sam |
#15 |
Move the bed back
#16 | |
Thanks |
#17 |
I really don't want to move the cross member it would be a PITA plus I think the spring would be misaligned.
I moved the bed forward to make it look better which it did, know I'm paying the price. I'm going to measure the wheel base. I will post my findings. ECC emailed me back, they see this a lot in lowered step sides. They would build me shorter arms. I asked where are you making them shorter (spring forward or spring back) |
#18 |
Moving the trailing arm crossmember forward, would require you to redrill the upper hole in the frame, for the spring retainer bolt.
I don't see that as much of an issue. Porterbuilt Fabrication makes tubular trailing arm crossmembers with a series of mounting holes to adjust the crossmember forward for the stepside trucks and rearward for the fleetside truck.
#19 | |
#20 | |
![]() Quote:
Was careful to cut the arms using the common "ZEE-CUT" for strength. Hope some of this helps. Sam |
#21 |
1961 crewcab
this is probably your best bet, getting them custom made, that way the springs stay in the right spot, and it should just be a bolt in affair... things to think about: the panhard bar (I think its called), will that have to be moved forward as well, and will you have to shorten the drive shaft, or is there enough slip play now that that is not needed? also what about he brake line? will it reach? , or maybe you could just move the mount on that as well.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#22 |
Reposition guards would be the simple answer if you don't want to move the whole bed back. Just a thought
#23 |
![]() Join Date: Mar 2011
Moving drivetrain components sounds like a bunch of work to an already superb chassis. Maybe pick up a couple of fenders and experiment with moving the wheel openings. I've seen it done on front fenders, I would think it could be done on rear step fenders.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
#24 | |
#25 | |
The panhard bar and the upper shock mounts will have to be moved. And the drive line will have to be shortened. The brake line should be easy move. I was going to remove the bed anyway this winter to do a C notch. I want to lower the rear just a little more. I guess I just can't stop working on this truck. (I think I need to see a doctor) Last edited by 66farmer; 11-19-2013 at 10:10 AM. |
