Old 01-17-2014, 02:24 PM   #1
JustTom
Is this dually Factory or "homemade"?
I ran across this truck on CL a while ago.
It was advertised as a 1988.
Is it a cab/chassis with a regular bed?
Or is it dual wheels on a regular truck?
This is the only pic, I have never seen it in person.
I have a 1984 4wd regular cab dually cab and chassis with a commercial flatbed on it.
I don't like the flatbed, it is too big and wide and I'd like to shorten the frame and put an 8' bed on it.
Tom
JustTom is offline   Reply With Quote
Old 01-17-2014, 02:33 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Is this dually Factory or "homemade"?
Homemade, or a mismatch of parts. The factory dually pickup will have the large add on fenders on it.
Keep in mind the dually pickups have a wider rear track. The cab chassis dual rear axle would be tucked closer inside the box side.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-17-2014, 03:39 PM   #3
SCOTI
SCOTI's Avatar
Agreed. Could have been a SRW (single rear wheel) 1-ton that had a cab & chassis (tow truck/flatbed) rear housing swap.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-18-2014, 02:37 PM   #4
nekkidhillbilly
thats a cab a chassis truck with a bed stuck on it
nekkidhillbilly is offline   Reply With Quote
Old 01-18-2014, 02:43 PM   #5
SCOTI
SCOTI's Avatar
How can you confirm this?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-18-2014, 02:44 PM   #6
meatwagon83
meatwagon83's Avatar
hit the nail on the head, i have seen this many times
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 01-18-2014, 02:49 PM   #7
nekkidhillbilly
how can you not? dual wheels that are as wide as a srw truck. unless he welded two frames together cause dual wheels on a srw truck will hit the frame. then its still a half c&c truck.
Old 01-18-2014, 03:41 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
http://www.pirate4x4.com/tech/billav...ble/index.html
SRW (single rear wheel truck) 67.5"
DRW (dual rear wheel truck) 72"
C&C (cab and chasis truck) 63.5"
Keith
Convert to disc brakes.
Old 01-18-2014, 03:49 PM   #9
Rubble
I can't find the thread right now,but isn't a cab & chassis 4" longer than a regular truck? Cab/box combo? I'm with SCOTI on this one,started as a CrewcabSRW that had a dually rear put under it.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 01-18-2014, 03:53 PM   #10
Rubble
I will have to measure the spring hangers for sure,but my 86 K25 was a converted dually when I got it.All the PO did was put longer studs on & he made it into a dually & the tires didn't hit the frame..
Old 01-18-2014, 03:55 PM   #11
nekkidhillbilly
and like i said the inside tire would hit the frame on srw truck. with this truck im sure they had to widen the tubs in the bed.
Old 01-18-2014, 04:15 PM   #12
Rubble
Just went out to shop & measured my 86,the spring hangers on same width as my other 3/4ton trucks.The 86 was a converted dually when I got it & the tires didn't come close to the frame.It has a deck on it,so tubs are not an issue.
Old 01-18-2014, 05:38 PM   #13
GM72K10
Next!
GM72K10's Avatar
Single Cab, Cab and Chassis would be longer than a pickup dually (135.5 vs 131.5) but a 4 door cab and chassis and a 4 door pickup (with or without box) have the same wheelbase (164.5).
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 01-18-2014, 05:57 PM   #14
lolife99
lolife99's Avatar
I think SCOTI is talking rearend width,... not chassis wheelbase.
Keith
Old 01-18-2014, 06:31 PM   #15
GM72K10
Next!
GM72K10's Avatar
I know it was an answer to Rubble
86 K30 CUCV M1028A1
Old 01-18-2014, 07:42 PM   #16
LONGHAIR
You can't bolt dually wheels onto a regular SRW axle, so it's width would not matter anyway.
Actual axle housing length is not really the issue, it is from one wheel mounting surface to the other that matters.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-18-2014, 08:42 PM   #17
Rubble
That's what I was thinking about,single cab & chassis..
Old 01-18-2014, 08:55 PM   #18
Rubble
That's the way this 86 was when I got it,looks like the PO put longer studs in,then bolted dually wheels to it.I don't have any pictures because I singled it out.Duals don't work very good in mud or snow.Its a14 bolt full floater under a 3/4 ton truck.I just changed to shorter studs & bolted some wagon wheels on.
Old 01-19-2014, 01:22 AM   #19
SCOTI
SCOTI's Avatar
My point was its just as possible it was a srw truck that had a rear axle swap..
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-19-2014, 10:12 AM   #20
nekkidhillbilly
srw axle with duals would hit frame the frame isnt as wide on cc in the back
Old 01-19-2014, 12:45 PM   #21
lolife99
lolife99's Avatar
I think you mean they would hit the leaf springs.
There is no way they would hit the frame first
Keith
Old 01-19-2014, 01:02 PM   #22
cory d
cory d's Avatar
my city has some
cory d is offline   Reply With Quote
Old 01-19-2014, 01:03 PM   #23
SCOTI
SCOTI's Avatar
Exactly. Seems more than 1 guy has swapped a C&C axle under a dually as an alternative to widening the dually fenders when doing the 10-lug big wheel swap.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-19-2014, 01:07 PM   #24
cory d
cory d's Avatar
in the truck i posted, the wheel tubs are a little wider. is it possible that i private company did this? i would love to built a narrow axle "big dooley"
Old 01-19-2014, 01:27 PM   #25
nekkidhillbilly
the leafs are no wider than the frame idk what you mean im saying the inside tire is gonna rub metal if you try it on a regular frame width truck. even without a bed.
