65 V8 long water pump, FAN SHROUD ideas?
A stock one won't fit and I don't want to cut up the perfect oe one that I purchased to make it fit. An aftermarket plastic one won't work and if cut down will have too large of fan opening by the time it fits ( 4" from rad to center blade)
Anyone run into this? Solution? My thoughts are fab up a nice sheet metal shroud or ditch all of the LWP stuff from the front of the engine and go with Short Water Pump stuff. Hoping someone says " oh yeah, just get a shroud from a ______and trim it ![]()
GOD BLESS AMERICA! |
60-66 Nut
Re: 65 V8 long water pump, FAN SHROUD ideas?
That's why I typically stick with short water pumps on the vehicles that originally came with them. Is your engine in the original location? I have seen other members run the long pump with a stock fan shroud, but when I tried it once, it didn't work. Not sure what the difference was.
![]() Join Date: May 2007
post 33 stock fan shroud long water pump with a clutch fan
http://67-72chevytrucks.com/vboard/s...=502124&page=2
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
^^^^^^ NICE! Now how good are you at shoving small cameras into tight spaces and getting a few pics? I would love to see which fan and clutch they are. My fan is flat and bolts to the backside of a fairly small clutch. Does the end of the taper area of the shroud land about half way through the fan blade if you dropped a plumb bob?
Thanks James!
I doubt you want to go electric fan but if you do I used a Lincoln Mark VIII fan. I had to trim a little off the top of the shroud to clear the radiator tanks and the radiator hoses and fab up brackets t mount it but I think it looks like it belongs there. While I was at it I installed a Radiator Overflow/Windshield Washer combo off a Ford Exploder.
ck out a chevelle big block 66/67 shroud. they are a little wider and bolt on flat but real short. can take a pic and measure if you want.
1961 chevy K10 my build is------------61K10 build |
#7 | |
Thanks!
#8 | |
#9 | |
here's one pic I have from before
#10 | |
The fan is off of a GM truck, I got it from board member teeitup he deals in 67-72.
Newfisher, do you realy need the thermostatic fan, if you just bolted on a 5 blade stock fan it would put it right where uou need it..?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#13 | |
I have found that a 86 suburban 350 fan and an aftermarket fan clutch with NO shroud runs cooler indicated on the gauge than an aftermarket fan bolted direct drive to the pump without a shroud.
#15 |
here is some pic's of the BB shroud--could be modded to work i think
27 1/2 wide 16 3/4 high 2 1/2 thick 19 1/4 fan opening
#16 |
Thanks, I will measure mine tonight!
#17 |
The fan shroud is a repo ( bowtie bits ) 70-72 7 blade clutch fan from board member Teeitup
#18 |
plumb bob, hope these help, if you need more just let me know
#19 |
Not factory looking but I've run an aftermarket chrome one for the past 15 years or so like this https://www.google.com/search?q=chro...90825447058319
#20 | |
#21 | |
