Old 01-26-2014, 12:33 AM   #1
E.D.75GMC
E.D.75GMC's Avatar
Need help figuring this out
Today I replaced the fuel pump on my truck, now the carb (quadrajet) is getting too much gas and it sputters and leaks all over the place. It ran fine until I took it back up the huge hill to get home, I was driving at 50/55mph the whole way up and with 4.10's in the back it was revving pretty high. Once I reached the top and let off the throttle it started to sputter, it limped home and I saw this when I opened the hood:
E.D.75GMC is offline   Reply With Quote
Old 01-26-2014, 12:34 AM   #2
E.D.75GMC
E.D.75GMC's Avatar
Re: Need help figuring this out
Gasoline was literally dripping off the carb around the base of the air cleaner
Old 01-26-2014, 12:42 AM   #3
E.D.75GMC
E.D.75GMC's Avatar
Another pic
You can see how wet the intake is from the fuel overflow
Old 01-26-2014, 12:46 AM   #4
joe231
joe231's Avatar
IMO, Could be a few different things...
Bad fuel inlet seat
Float may need adjusted
Trash in the fuel inlet not allowing the seat to close
Fuel pressure too high
Bad float
I'd check fuel pressure first, everything else will most likely require disassembly, a rebuild, and new gaskets.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-26-2014, 01:07 AM   #5
E.D.75GMC
E.D.75GMC's Avatar
Hmm how do you check the fuel pressure?
Old 01-26-2014, 01:20 AM   #6
Paul83
Paul83's Avatar
Is this an electric fuel pump?
I don't care how old or gangster you think you are; if a 3 year old hands you a play phone you answer that!
I like long walks on the beach, dinner by candle light, and poking dead things with a stick.
Paul83 is offline   Reply With Quote
Old 01-26-2014, 01:21 AM   #7
E.D.75GMC
E.D.75GMC's Avatar
Nope it's mechanical. It's a 1975 3/4 ton with a 350.
Old 01-26-2014, 01:26 AM   #8
joe231
joe231's Avatar
Fuel pressure tester or inline gauge
CHEVY ONLY
Old 01-26-2014, 11:30 AM   #9
cadillac_al
It looks like the float got stuck. I had a float stick on my convertible last summer. I took it off on the side of the road in less than 5 minutes and brought it home, took it apart, and noticed the float has a little drag to it but nothing drastic. I put it back together and it hasn't done it again. Mine was just a fluke, yours could be a bad needle and seat at the worst. It's still easier than trying to sort out an efi problem.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-26-2014, 12:04 PM   #10
donut
donut's Avatar
Check everything joe231 posted. Personally I'd look for trash in the carb. Reason I'd start there, I haven't rigged up a pressure setup yet and you did just break loose the fuel lines.
My thinking, you just increased the fuel pressure/flow with the new pump plus breaking loose the lines= far greater chance for breaking something loose. (deposit, flap of gasket, general dirt...)
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
