#26 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Longbed-Shortbed Conversion
#27 |
GoatLube Experss
![]() Join Date: Oct 2009
several have mentioned the better ride with a long bed, I have a crew cab short bed (1/2 ton) and it rides great with the add'd wheel base the crew cab add's.
I've always preferd short bed to long bed's but I do see the benefit of a long bed , its just harder to make em look good.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#28 |
I personally like the LWB, they look sleeker going down the road... As was said, if they are set right...
2024 Silverado Z71 PPV 1972 Chevy Monte Carlo 2018 Buick Enclave (Wifes) |
#29 |
Thanks!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#30 | |
Slim
Long live SLIM ------------------ At least try to buy American
#31 |
Slots go on anything!
There was a truck on here that was done that way, IIRC. You might be able to get away with it on a 1/2 ton, but on my 3/4 ton the height of the rails makes me think it might be a limiting factor, unless you cut off some of the height of the rail. At that point, it might just be easier to section them.
1974 Jimmy- 5.3/4L80e/NP241 |
#32 | |
Thanks much
#33 |
You will have to drill the holes for the rear gas tank mounts too. I used the sections of frame that were cut out as a fishplate and sleeve and it worked out pretty slick, too.
#34 | |
Slim
#35 |
GoatLube Experss
you will have to use 16 gal tanks (SWB), 20 gal (LWB) will not fit, it can all be done in a day if you have everything lined up. the drive shaft would be the only issue, most have there cut done. On mine I went from 1ton to half ton so I need'd a new shaft. I discover'd that front half from a late '80 Suburban and a mid '80's Delta 88 work out to be the perfect length .
#36 | |
| Bookmarks |
| Tags |
| long bed conversion |
| Thread Tools | |
| Display Modes | |
