Old 02-11-2014, 11:39 PM   #33
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: Longbed-Shortbed Conversion
Originally Posted by slimneverdies View Post
That's what I was thinking too. I'm trying to figure it all out with the bed still attached. Well I guess there's no other way around it. Sectioning it from the middle definitely will take so more time removing/relocating gas tanks and all
Thanks much
you will have to use 16 gal tanks (SWB), 20 gal (LWB) will not fit, it can all be done in a day if you have everything lined up. the drive shaft would be the only issue, most have there cut done. On mine I went from 1ton to half ton so I need'd a new shaft. I discover'd that front half from a late '80 Suburban and a mid '80's Delta 88 work out to be the perfect length .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
long bed conversion
