Old 02-12-2014, 08:14 PM   #1
yellow400ex05
Question TH400 skips 2nd gears goes right for 3rd
Alright I just bought a '84 C10 with a TH400 and a BBC and for some reason 2nd gear works fine when shifted manually but but accelerating in drive it'll go from 1st to 3rd.
what would cause this issue?
yellow400ex05 is offline   Reply With Quote
Old 02-12-2014, 09:35 PM   #2
geezer#99
geezer#99's Avatar
Re: TH400 skips 2nd gears goes right for 3rd
You need to adjust your vacuum modulator. Pull the vac hose off and use a small flat screwdriver and turn the screw out (it's inside the hole) 6 turns to start. If it gets better then turn it out 6 more.
Old 02-12-2014, 11:08 PM   #3
rs74
rs74's Avatar
Does this apply if the transmission shifts really fast. I will just start to get rolling and mine shifts to second and third comes early as well with my 400 turbo.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-13-2014, 12:16 AM   #4
geezer#99
geezer#99's Avatar
Yes it does. You need to fine tune it. Try for going into 2nd at 15mph and to third at 25 to 30 mph.
Old 02-13-2014, 12:24 AM   #5
yellow400ex05
i almost feel like mine does that, i cant tell, but if it does its going immediately from 2nd to 3rd. making this truck feel very slow. i'll get a new vacuum modulator and vacuum line and have it adjusted, hopefully that fixes it, because it'll downshift if your already in 3rd and manually drop it to 2nd still, so everything seems to be okay except for that.
Old 02-13-2014, 12:31 AM   #6
Ozzy2013
Ozzy2013's Avatar
Make sure to check your governor it uses the vacuum modulator to control the rate that the centrifical weights in the governor open they could be sticking and not swinging out like they should .Its an easy fix!Hope this helps you !Oz
Ozzy2013 is offline   Reply With Quote
Old 02-13-2014, 12:37 AM   #7
yellow400ex05
where is the governor you speak of? how do you go about checking it? I'm not familiar with these transmissions
Old 02-13-2014, 12:42 AM   #8
geezer#99
geezer#99's Avatar
Thanks Ozzy.
That's the second half of the cure. I always try adjusting the modulator first.
Don't go running out and getting a new modulator Yellow400. Try adjusting yours first. Easy to do. Pop the hose off and rotate the screw. You might need to go a couple dozen turns to get it right or only 6 turns. Go easy. Test and adjust some more.
If you find no change then it's governor time.
Also if any adjustment on the modulator does nothing at all then it's possible the po installed a new one but left out the internal pin. I've seen that before.
Old 02-13-2014, 01:11 AM   #9
yellow400ex05
Thanks Ozzy.
alright thanks, is there any specific way to turn it, left or right? what will it do?
sorry for the questions just want to know what the cause and affect will be before i go and mess with it!
Old 02-13-2014, 01:53 AM   #10
geezer#99
geezer#99's Avatar
Turn the screw clockwise. Remember where you start. Count the turns. Go six and see if that changes anything. If it does the shifts will be longer between gears and firmer. You can go to far and make the shifts too hard. Best to be conservative.
Old 02-13-2014, 03:32 AM   #11
Ozzy2013
Ozzy2013's Avatar
It is under the modulator cover on the right side of the trans its behind the Big round Cover.
