Old 02-13-2014, 12:31 AM   #6
Ozzy2013
Ozzy2013's Avatar
Re: TH400 skips 2nd gears goes right for 3rd
Make sure to check your governor it uses the vacuum modulator to control the rate that the centrifical weights in the governor open they could be sticking and not swinging out like they should .Its an easy fix!Hope this helps you !Oz
Ozzy2013 is offline   Reply With Quote
