Old 02-16-2014, 11:04 AM   #1
cochino12
It followed me home?
cochino12's Avatar
will Ford alcoa dually wheels work on a k30?
So I've been searching all morning and cant seem to find exactly what I'm looking for here. I've got a chance to pick up some free Alcoa dually wheels that were pulled from a mid 90 ford dually. From what I understand the fords use a slightly larger hub so factory steel wheels wont work on a chevy but what about the aluminum Alcoa's? Anybody tried them?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-16-2014, 11:23 AM   #2
rs74
rs74's Avatar
Re: will Ford alcoa dually wheels work on a k30?
I want to say 97 and older will bolt up although I believe the hub whole may need opened up. I am not 100% on that but that is what comes to mind.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-16-2014, 11:33 AM   #3
b454rat
they will fit. Ford used a bigger hub, therefor the wheel opening will be larger. Now Gm wheels are the opposite, so they won't fit on a Ford.
Old 02-16-2014, 11:34 AM   #4
80SPORT
80SPORT's Avatar
The center of the ford rim is larger so you will need to machine a sleeve to center on the Chev hub;they will bolt on without the sleeve but will not run true.
80SPORT is offline   Reply With Quote
Old 02-16-2014, 11:39 AM   #5
rs74
rs74's Avatar
I am glad you guys straightened that out. I couldn't remember which way it went.
80SPORT, do you have any pics or links of a sleeve being made for this application? I would like to see a pic of this if possible.
Roy
1987 R10 shortie
Old 02-16-2014, 11:42 AM   #6
cochino12
cochino12's Avatar
That's what I thought, but how is it that an eagle dually wheel will fit both a ford and chevy without a sleeve for the hub?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-16-2014, 11:52 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
All of the Eagles I've seen use the self centering Mag type of shouldered lug nuts. They rely on the lugnut and stud to carry the load rather than the hub centric.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-16-2014, 11:54 AM   #8
cochino12
cochino12's Avatar
Do you know if the Alcoa wheels will work with that style lug nut?
thanks for the help guys
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-16-2014, 12:04 PM   #9
Tx Firefighter
Absolutely not. The Alcoas have small lug holes, just big enough for the studs, but not big enough for the shouldered lugnuts. I guess you could easily drill the lug holes bigger though.
Old 02-16-2014, 12:20 PM   #10
plumbers crack
plumbers crack's Avatar
Measure the pattern first, Ford changed to a metric pattern in 99. I'd take them anyways and sell them for one's that fit.
Are they they the 5 star or 8 hole? I beleave that the 5 stars are in the new pattern, unless they are ea wheels.
The spacer your looking for is called hub centric rings, you should be able to get them at any tire shop.
1990 GMC R35 CC dually, VE cummins, 47RH
2005 Silverado ecsb, 5.3, 2/4 drop, daily work wagon
2000 Yukon xl, 5.3 all stock, wife's truck
2007 Yukon Denali, 6.2 back up truck
plumbers crack is offline   Reply With Quote
Old 02-16-2014, 12:49 PM   #11
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Check bolt pattern , I did not think ford and chevy were the same. Dodge and chevy are the same with different size center bores. Dodge will fit chevy but chevy will not fit dodge. Chevy is 8 on 6.5 until 2011 and then they changed to 8 on 180.
ksbrktracer is offline   Reply With Quote
Old 02-16-2014, 01:47 PM   #12
rs74
rs74's Avatar
This is my understanding. The Pre-97 (or is it 99?) Ford Alcoas will fit and most all the Dodge wheels should fit because they are 8 on 6.5". The newer Fords will not fit because they are 8 on 170mm. I believe depending on which way you are going some hub centers needs bored and some may require the hub centric rings. That's just from a little research I did. How accururate that is I don't know but that is what I come up with.
Roy
1987 R10 shortie
Old 02-16-2014, 02:48 PM   #13
nekkidhillbilly
you can by centric rings
nekkidhillbilly is offline   Reply With Quote
Old 02-16-2014, 02:49 PM   #14
nekkidhillbilly
pre 98. the 97 was the last square sd.
Old 02-16-2014, 03:00 PM   #15
cochino12
cochino12's Avatar
I've been looking online for some rings an found a few sources, now I just need a caliper big enough to measure the hub and wheel centers haha
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-16-2014, 03:50 PM   #16
plumbers crack
cochino12, you can take one of each wheel to a machine shop and have them make you a set.
Old 02-16-2014, 04:53 PM   #17
80SPORT
80SPORT's Avatar
I think you ned the HR125-116 rings
About 12.00 each
But measure first before ordering.
(wheel center 124.9 mm....hub od 116.7 mm)
Old 02-16-2014, 08:38 PM   #18
cochino12
cochino12's Avatar
You guys are awesome, I appreciate the help.
80sport, those numbers look right on. Thanks
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
