LMC tachometer
Has anyone done the LMC swap to include the wire harness they sell? Is it simply a matter of swapping this in and then adding the smaller fuel gauge in the cluster to the left? I have dual tanks also and arent sure if that effects anything
Happy to be here
![]() Join Date: Mar 2000
Re: LMC tachometer
Anyone?
Re: LMC tachometer
That lmc tach seems to be a replacement tach for a tach cluster. Regular clusters housings are not the same.
John 82 Chevy Silverado 350ci/TH350
Re: LMC tachometer
you would need the back overlay for it to work with gas gauge
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Re: LMC tachometer
I could of sworn I read installing a tach was as easy as finding one and using the smaller fuel gauge.
Im sure SOMEONE can verify, with some pics hopefully. |
Re: LMC tachometer
Re: LMC tachometer
As far as I could tell when I was rigging up my tach cluster the printed circuits on the back are all the same all you have to do is relocate the metal tabs that the gauges slide into (if you moved the fuel gauge to the bottom left). I had to modify my plastic cluster housing for a tach as the bottom is larger with the combo tach/fuel gauge. It's very easy to do though.....
There is a little plastic piece that goes into the housing that the tach mounts to i unfortunately don't have pics of it. I wanted my cake and eat it too lol I found a tach fuel gauge combo and a clock! |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: LMC tachometer
I "FRANKENSTIENED" mine to include an air pressure gauge in the lower left corner.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
#9 | |
Re: LMC tachometer
search threads about adding tach etc, surely this was discussed before.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB Last edited by 88Jimmy4x4; 01-05-2013 at 09:39 AM. |
I know the pieces fit
Re: LMC tachometer
I think this one is plug n play, well, after running the tach wire: http://www.gmsportssalvage.com/?q=node/1530
MOTORHEAD!
Re: LMC tachometer
Is anybody running the above tachometer?
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi/3.42 Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Ryan Brown Performance 850 Holley Full weight long box pickup Current best- 11.28@119mph |
#12 | |
Re: LMC tachometer
http://67-72chevytrucks.com/vboard/s...e+combo&page=3
#13 | |
Re: LMC tachometer
I could be mistaken but the fonts look as though they would only match later years. |
#15 |
MOTORHEAD!
Re: LMC tachometer
Thanks Firebirdjones! DEFINATLY ordering now!!!
#16 |
Re: LMC tachometer
Very interesting! I thought about the LMC tach and moving the fuelgauge to the clock location since it doesn´t work anyway! Only drawback is that the little gauges are hard to read for tall persons because the don´t angle upwards!
Volker
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ![]() ´81 GMC C 10, Spanish Red |
#17 | |
Re: LMC tachometer
This is just the best setup i have see.... |
#18 |
Re: LMC tachometer
I dont see how the printed circuits are all the same when they sell so many different versions. They make look the same to the untrained eye but if you follow the start and end of the embedded copper trace they go to diff locations.
![]() ![]() heres a non tach cluster first and tach cluster last two pics for comparison
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB Last edited by 88Jimmy4x4; 01-06-2013 at 10:05 AM. |
#19 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: LMC tachometer
The printed circuit on the tach vs non tach aren't the same, in addition, the actual housing isn't guaranteed the same either.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#20 |
Re: LMC tachometer
I bought the LMC Tachometer and wiring harness and of course it didn't come with a wiring diagram. After thinking of it a couple of days I got my multimeter, 12v power supply, spare distributor, and wired up tach to test my theory that the threaded terminals that would plug into the fuel sending unit are probably not needed and they aren't, the tach moved with power, ground and the signal from the dist.
A solution to some setups w/o oe tachometer? 81 Chevy C10 w/o tach, check out the pictures for install. Only +, Neg-, and (S)ignal are needed for this tach to work, cut the factory threaded terminal screws! I RESET MY ODOMETER WHILE I WAS AT IT!!! |
#21 | |
Enthusiast
Re: LMC tachometer
- Cole 1979 Chevy C30 w/ carb 454. 1992 Chevy K1500 w/ tbi 350. *Sold* 1997 Dodge Ram 1500 w/ Magnum 360 *Sold* "Good judgment comes from experience. Experience comes from poor judgment." - George Washington |
#22 | |
Re: LMC tachometer
Nice job!
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
#23 | |
78K & 79C Jimmys
Re: LMC tachometer
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#24 |
78K & 79C Jimmys
Re: LMC tachometer
the board is different too for idiot lights,my 78 the gauge location changes too
#25 |
Re: LMC tachometer
Nice work.
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
