Any pics of DIY rear upper shock mounts?
lakeroadster had a good thread on this, but he is currently blocked for some reason and none of the pics show up on my computer. Was thinking of doing this as well as moving the shocks to the outside of the frame like 66farmer did for room to run the exhaust.
Re: Any pics of DIY rear upper shock mounts?
No Limit makes a kit like that.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
^^^^^^^what he said.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
Yes, I am well aware that I can buy these from many vendors, but am asking about a DIY version. For a few dollars in scrap metal and a little time, and also to give a little fabrication practice, that's what I want to do.
Soooo, can anyone help me out with this? |
I think the first thing they do is take the stock shock brackets, swap them side to side and front to back, then elongate the holes to allow them to be rotated slightly (bottom shock bracket) . Am not sure about the top bracket it might just be as simple as installing a upper shock stud thru the frame and voila your shock brackets are there and inexpensive. I have not done it myself but have looked into it for the same reason, to save money......Kieth
I found it! I looked for about an hour yesterday. Just gotta put the right words into the search function I guess.
#7 | |
GOD BLESS AMERICA! |
Ah, yes, that would be a good idea.
Here's lakeroadster's, the original one I was looking for, see post 51: http://talk.classicparts.com/showthr...t=13928&page=4 Here's frizzlefry's that also moves the shocks outboard,s ee post 11 (and a supercute helper): http://67-72chevytrucks.com/vboard/s...postid=4730005 Here's SCOTI's: http://67-72chevytrucks.com/vboard/s...d.php?t=437582 Hopefully this might help someone else at some point. |
